Evo IX 4g64 destroked 2.2l Pressurizing Cooling System
Old Mar 2, 2013 | 08:39 PM
ExViTermini's Avatar
Most any gasket u find is gonna be sized to 87mm(ie a .020/.5mm overbore)
Old Mar 3, 2013 | 05:56 PM
JGNERAEVO9's Avatar
Question
Fast Freddie is your 4g64 oringed?
Originally Posted by Fast_Freddie
Make sure to retorque the 625 headstuds! Had same issue...
Old Mar 3, 2013 | 06:51 PM
Fast_Freddie's Avatar
Veteran: Navy
Nope... put new resurfaced head on and put in some 625 headstuds... didnt retorque them and popped the radiator... retorqued them (a few needed turned 1/4 turn) and burped system again and havent had any issues...
Old Mar 3, 2013 | 06:58 PM
JGNERAEVO9's Avatar
How much power and PSI?
Old Mar 3, 2013 | 07:00 PM
JGNERAEVO9's Avatar
How much power and PSI and did you prep the block too?
Old Mar 4, 2013 | 07:40 AM
Veteran: Navy
Power around 550 at 33psi... block was cleaned but not resurfaced, the head was decked and cleaned before install, using a cosworth head gasket... like I said, my mistake for not retorquing the studs...
Old Mar 5, 2013 | 02:30 AM
evoyrrah's Avatar
happened to me too....it was headlift!!! i ended up replacing hg and upgraded to L19s and problem stopped......my head was warped also so got it milled......simple
Old Mar 23, 2013 | 05:46 AM
R/TErnie's Avatar
I run a 4g64 mivec that is destroked and 87mm. I used a Cosworth hg and map L19 head studs. Never used coolant. I retorqued the head studs, but they hadn't moved.
Considering doing an o ringed setup this go around
Old Mar 7, 2014 | 07:14 PM
evl08's Avatar
Bringing this back.
If you're going with 0.020" over to 87mm on the 4G64 and have a chamfer on the cylinders, does the gasket need to match the chamfered surface or the 87mm of the cylinder bore.
I notice the stock head gasket is wider than the cylinder bore and matches the cylinder chamfer which i assume is done to prevent having the head gasket poke out and create a hot spot or prevent carbon collecting underneath.
evolve_VIII
444
Dec 16, 2020 08:11 PM
bigturboevo03
41
Feb 11, 2017 09:57 PM
foxbat
16
Aug 4, 2016 07:45 PM
rodent
41
Oct 13, 2015 08:00 AM
bab090
38
Jul 19, 2013 03:35 AM
