is it critical damage for exh. wheel ? **pics**
Old Feb 28, 2013 | 11:35 PM
stunt2's Avatar
turbo was without hotside and got damaged during transporting
how bad is this kind of damage and what will it affect if I leave it that way ?
or should I attempt to heat them and straighten gently with pliers ?
Attached Thumbnails is it critical damage for exh. wheel ?  **pics**-dsc_0037-2.jpg   is it critical damage for exh. wheel ?  **pics**-dsc_00382-1.jpg
Old Feb 28, 2013 | 11:45 PM
adriano_917's Avatar
Out of balance, dont run it like this! Contact fp performance, cbrd, or map.
Old Feb 28, 2013 | 11:52 PM
stunt2's Avatar
Im not in states and no balancing shop around unfortunately
have only three options
1. heat and attempt to straighten fins
2. swap exh.wheel along with shaft (have another laying around, but this option will still remain unbalanced)
3. leave as is
Old Feb 28, 2013 | 11:59 PM
Piro Fyre's Avatar
I would pay the extra money to ship it to FP or a turbo specialist to fix it. Remember, these spin at 100k RPMs and even higher so balance is very important. Either that or send it back to the guy and get a refund.
Old Mar 1, 2013 | 12:39 AM
foxbat's Avatar
Hey Stunt, are you running anti lag? :]
Old Mar 1, 2013 | 01:12 AM
rstchris's Avatar
If there is no material missing, it shouldn't be out of balance as weight is concerned. Chances are, when you straiten them, the geometry won't be exactly the same making a small pressure imbalance. This may or may not cause issues in the future. I have seen wheels missing significant ammounts of material from anti-lag damage and run fine for thousands of miles. If you can't afford it to fail, don't use it.
Old Mar 1, 2013 | 01:44 AM
way2qik's Avatar
This is exactly correct. Balance has to do with weight, not the angle of the fins. Your turbo isn't missing any weight, therefore, it is still balanced to whatever degree it was balanced prior to the the bending of those blades.
I would heat those blades up and very carefully bend them back into position as best you can. In the end, if you do it correctly, you'll never even know it happened.
PS. I'm speaking here from personal experience as I did this on an exhaust wheel of a Borg Warner S480 years ago. Put it on the car and it ran like a champ.
Old Mar 1, 2013 | 01:45 AM
stunt2's Avatar
foxbat no, I'm not read the first post
so what do you suggest
1. mark wheels/shaft/nut from my another turbo, dissasemle it and swap these parts to this chra, then reassemble accordingly
2. attempt to straighten pins
3. leave as is and install on the car
Old Mar 1, 2013 | 01:47 AM
stunt2's Avatar
way2qik
yep, I'm leaning to that idea too, only thing that's holding me back is that small krack on one of the fins and the danger to not brake it off
Old Mar 1, 2013 | 03:35 AM
Teal2nnr's Avatar
Bend em back....it appears that is realistically your only option anyway.
Old Mar 1, 2013 | 04:48 PM
I didn't mean out of balance as in weight but as in turning the way it should, the wheel is suppose to be perfectly balanced.
Old Mar 1, 2013 | 05:48 PM
BBC's Avatar
BBC
Is it worth your whole motor? If you bend it back you will fatigue the metal, and the wheel is likely designed to maintain integrity to 1,700 degrees f + so good luck heating it. That sucker spins up to 100,000 rpm and the slightest centrifugal imbalance is no small matter. The wheel is toast.
Old Mar 1, 2013 | 06:02 PM
msrevo's Avatar
i would definitely pay. just get it fixed
Old Mar 1, 2013 | 10:54 PM
BEKevo's Avatar
I know weight determines the balance, so theoretically he should be fine.. But just think of the stress the turbine wheel is exposed too. I would just buy a new wheel, preferably a new MHI turbine wheel.. You might as well do it once, and right.
Old Mar 1, 2013 | 11:45 PM
-Jarred-'s Avatar
As I mentioned on evo123.net - a 10 degree backcut will clean that up along with increasing flow and top end with barely any noticeable difference in spool/lag (none at all in my experience).
I'd pay to send it away for a 20G upgrade with the above backcut myself.
