Catless cars
Old Mar 9, 2013 | 11:49 PM
Viegasjuice's Avatar
Originally Posted by adriano_917
Its prolly starting to leak, do a leakdown test that should tell you right away. If its a headgasket(bubbles on reservoir/radiator) get an OEM and Arp head studs. Dont wait too long!
You mean headgasket starting to leak?
Old Mar 10, 2013 | 08:46 AM
barneyb's Avatar
Which do you have, cat or muffler?
Old Mar 10, 2013 | 09:38 AM
boostedwrx's Avatar
If it's been raining out, is very damp or humid, or is just very cold out you will see lots of white steamy exhaust from the condensation. If it's a dry day, temp in the 60's or higher you shouldn't see any exhaust, if you do it's something else.
Old Mar 10, 2013 | 10:18 AM
heel2toe's Avatar
This is what came to my mind when I read through this thread. Everyone here was quick to jump in and say that it is burning coolant from a potential headgasket leak.
While it may indeed be a leaking headgasket, before you go pulling the head, I would insure that its not just the cold weather causing the white exhaust.
Old Mar 10, 2013 | 10:21 AM
JDMevoBOOST's Avatar
He is saying at WOT though. Normally if it's condensation you will only see it for the first 5 mins after startup.
The real question should be why the hell is he driving a cammed car with no tune?
Old Mar 10, 2013 | 10:33 AM
heel2toe's Avatar
I believe he asked at both idle and WOT. You are right, the car should definitely be dialed in by a competent tuner. Nonetheless im not so sure that is is indeed burning coolant and think it could be something as silly as typical white smoke during the cold.
Old Mar 10, 2013 | 11:42 AM
barneyb's Avatar
In another thread the OP says he has a muffler but no cat then changes his mind and says he has a cat but no muffler. Also, he states there's a code for running too rich. So, anyway, I think he is new to the car (and car mechanics).
Old Mar 25, 2013 | 11:37 PM
Sorry, and yes im a noo for sure. Its a catless buschur tbe.
Old Mar 26, 2013 | 11:18 AM
barneyb's Avatar
I've seen cars that were very very rich and they had white smoke out of the exhaust. The white smoke was just unburnt fuel. There was also a strong odor of gasoline.
Old Mar 26, 2013 | 11:41 AM
Ev0ikon's Avatar
Check and clean out your PCV also. My car was smoking white when I had a fowled up PCV.
Old Mar 26, 2013 | 12:31 PM
evo8426's Avatar
Originally Posted by Viegasjuice
What if it has gsc s2 cams/ bushur tbe exhaust and without a tune. System rich code.
What injectors? System rich sounds like your fuel trims are maxed out and throwing P0172 code.
If stock injectors, perform a boost leak test and clean your MAF.
Old Mar 26, 2013 | 08:10 PM
X Double Dot's Avatar
Another check to tell if it's burning coolant/got a bad head gasket is to pull the plugs
IF they look brand spankin new they've been steam cleaned from the coolant vaporizing (unless they are indeed brand spankin new). This is most valid if you have old plugs, and one shows up really clean and the others are old looking.
Other people have mentioned it above, but check the coolant and oil for contamination/bubbles.
Also, how old/watered down is the gas in the car, or is it fresh?
Old Mar 26, 2013 | 08:19 PM
Ramen_Noodle's Avatar
How cold is it outside in NOVA?
Do you leave a trail of smoke at WOT?
Rallykid21
Nov 19, 2016 01:20 PM
Ralliart367
22
Jan 20, 2013 01:09 AM
fernani
14
Dec 9, 2010 07:30 PM
DanRHeller
Oct 29, 2010 11:32 AM
IDRINKV8
39
Jul 15, 2008 07:53 AM
