Mounting Locations for MBC?
Old Feb 15, 2004 | 07:47 AM
AMX's Avatar
AMX
I am about to install a Hallman MBC and was hoping to learn from others where (and how) you mounted your valves (I understand the plumbing, what I'm interested in the physical valve location/mounting). Do you need to rigidly mount the valve or do they just "hang" on the vaccuum line? Also, does anyone have any suggestions about locating the valve to provide easy access? Pictures would be helpfull.
Old Feb 15, 2004 | 08:04 AM
Satori's Avatar
I used zip ties to fix it to the hoses on the right side of the valve cover. On my GS-T I had it zip tied to the fan housing.
Put it where you like it best.
Old Feb 15, 2004 | 08:22 AM
propellerhead's Avatar
I mounted mine using one of the bolts on the thermostat housing.
Old Feb 15, 2004 | 08:31 AM
4-BNGR's Avatar
Bolt it to the battery bracket using a wing nut to tie it down
Derp
64
Jan 14, 2021 08:16 PM
sabastian458
25
May 8, 2013 12:49 PM
aggieEVO
Jan 16, 2013 05:18 PM
Evo J
12
Oct 19, 2009 07:22 AM
rodman
Mar 19, 2006 06:22 PM
