What is this? (Need ID on wire to block)
Old Mar 17, 2013 | 02:04 PM
marcusE's Avatar
Looks like it attaches to a ground of some sort on the block towards the passenger side
It fell off today and when I tried to attach it back the wire just twisted with it completely off.
I think it connects to the lower left bolt in this picture
Old Mar 17, 2013 | 02:07 PM
thebluesky's Avatar
What you have circles is a knock sensor.
Old Mar 17, 2013 | 02:08 PM
marcusE's Avatar
Read what I said, LOWER LEFT of block. Not the knock sensor thats just the only picture I could find.
Old Mar 17, 2013 | 02:21 PM
ExViTermini's Avatar
Only other thing there is the oil pressure switch
Old Mar 17, 2013 | 02:22 PM
marcusE's Avatar
It looks like the flat piece slides into a black connector that's part of the tranmission harness of sensors..
Old Mar 17, 2013 | 02:24 PM
Trans harness is small, and only entails the backup lamp switch and vehicle speed sensor, and it goes back towards the front of the car and connects at the thermostat housing. What are the wire colors?
Old Mar 17, 2013 | 02:31 PM
marcusE's Avatar
The wire end of the piece I'm holding connects to an eyelid that is connected to the block via a silver small phillips head screw, The flat part of what I'm holding connects to the harness that has 1 blue and white colored wire, which is part of the harness that has the ground on the transmission as well as the starter connections
Old Mar 17, 2013 | 02:37 PM
The gold thing to the left and down of the circled thing(knock sensor as previously stated) in the pic you posted is the oil pressure switch. According to the manual the wire colors for it are blue/yellow. The connector on the end of the wire you are holding is not a factory connector.
I'm assuming someone has done a repair on that wire in the past, and that is the spade connector that is on the piece in your hand.
Jose Aliling
Oct 30, 2012 12:57 PM
marcusE
Oct 26, 2012 02:53 PM
MRadjahoe
For Sale - Wheels / Tires
Apr 18, 2012 12:56 PM
Revobasher
Mar 12, 2012 01:33 PM
dh19evo
36
Feb 5, 2012 12:26 PM
