Help: Anyone recognizes this cams?
Old Apr 4, 2013 | 06:54 PM
2f@st's Avatar
I bought the car with this cams, I'm gonna install a green hta and I would like to know if there good enough. I removed the valve cover in search for marks. They have dark orange paint and some marks.
Here some pics.
cams
cams mark
other marks
Old Apr 4, 2013 | 07:02 PM
sktng22's Avatar
only first pic is working
Old Apr 4, 2013 | 07:06 PM
EVO8_PR's Avatar
Something must be wrong on your end, I see all three. But don't have a clue as to what cams they could be.
Old Apr 4, 2013 | 07:52 PM
JohnBradley's Avatar
Pull one of the cam caps nearest the cam gear.
Old Apr 4, 2013 | 07:57 PM
bitterchild's Avatar
the "KG" and "ES 4604" are the identical markings that are on my early version GSC S1 non-mivec. That could only mean that the cams are made from the same blanks which are sold to several aftermarket cam companies. My GSC S1's also have the same brown marks, 3 on the exh, 2 on the intake. Best bet is to ask GSC directly to confirm.
FYI specs on the early (pre 2008) GSC S1's are 10.98/10.2 268/266
Old Apr 4, 2013 | 08:07 PM
2f@st's Avatar
Thanks guys, now I have a clue, I would contact them.
JohnBradley: What I should look for when removing the cap?
Old Apr 4, 2013 | 08:17 PM
There's another set of numbers under there that might help you identify them. I think they're "batch" numbers.
Old Apr 4, 2013 | 08:27 PM
It will be under the cam seal so you will have to wiggle it a little bit.
PPA is S1
PPB is S2
PPC is S3
...if they are GSC cams
Old Apr 4, 2013 | 08:32 PM
2f@st's Avatar
Ok thanks guys!
samurai85
Mar 11, 2015 03:32 PM
chamelieon
33
Mar 3, 2015 05:22 PM
Jimmy Javelin
11
Jun 8, 2014 07:50 PM
nefarious_Saint
For Sale - Wheels / Tires
Nov 8, 2013 12:44 PM
mr.alex
Aug 14, 2009 04:46 AM
