I have replaced everything..... But still...
Old Apr 3, 2013 | 01:56 PM
88888's Avatar
Unhappy I have replaced everything..... But still...
Hello EvoM.
I have recently gone through a clutch fluid pressure loss issue and ended up replacing
Transmission (Buschwacker)
Brake master cylinder
Brake slave cylinder
Clutch cable to SS
Brand new exedy twin clutch with floater plate.
Now after all these parts have been replaced, I am still having an issue with my exedy twin when its engaging. I feel like the plate is just not coming back up far enough (dragging)
my 1st -> 2nd is not smooth and it feels like it gets "stuck' while shifting
This does not happen if i shift fast. Even after adjusting the clutch pedal bar length, it seem to come back to the same problem after a few days.
What do you suggest i check?
what could be an issue here? is it fluid pressure related issue still?
thank you
Old Apr 3, 2013 | 08:30 PM
minimarine09's Avatar
im assuming your restrictor "pill" is removed from inside your slave cyl?
Old Apr 4, 2013 | 10:33 AM
88888's Avatar
OEM Slave was installed. im not sure about the restrictor pill...
Old Apr 4, 2013 | 10:49 AM
05blue8's Avatar
You need to remove it for sure.
Another suggestion is to send your clutch to Exedy and have the entire thing checked for warping. Directly from Exedy -
"A warped pressure plate, intermediate plate, flywheel, improperly machined flywheel, or if there is debris build up in the diaphragm spring pivot area in the clutch cover, all these things can cause clutch drag."
Old Apr 4, 2013 | 10:56 AM
the restrictor pill is inside the slave cyl inbetween the bleed screw and the clutch line, just take those out, pop out that little plate looking thing with tiny hole and spring( thats the restrictor) and put the bleed screw back in and the line, then bleed again and see how it feels. if it was in there and you took it out, you should feel a more predictable engagement point, maybe it is the cause of your issue as well? just a thought. good luck!
Old Apr 4, 2013 | 01:38 PM
88888's Avatar
restictor pill was removed and i just confirmed it.
It has to be some other issue.
Does anybody have any other suggestions?
Old Apr 4, 2013 | 08:41 PM
djdnav's Avatar
I had similar issues, so I'm trying this
http://www.jackstransmissions.com/pa...clutch-warning
Old Apr 4, 2013 | 09:14 PM
^^^ouch. that sounds promising but unfortunate that you have to do all that labor
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
hoino11
Lancer Tranny/Drivetrain Tech
Jun 18, 2014 11:02 PM
tsidrift1
39
Feb 4, 2014 05:15 AM
