Balance shaft removal in car questions..
Hey guys,
I've done and seen the balance shaft removal and bearing install with the engine out of car. pretty straight forward.
My question is this...
Has anyone had any luck, since the engine is in the car,installing the stub shaft or AMS type shaft and leaving the other shaft disconnected but the gear still on for the balance belt.
I have seen this and it says it is possible: http://www.vfaq.com/mods/balance-shafts.html
Thanks for your input.
I would never do that. The balance shafts have oil grooves in them that if the shaft moves to the wrong position can allow too much oil to escape causing low oil pressure at idle and damage to the bearings. I have removed the balance shafts in the car and it is a pita but well worth it.
Yeah, I got the oil pan and pump out already.
Just the stupid rear shaft only comes out half way because you have to angle it down to remove. I was thinking cut the damn shaft in half then acess both rear bearings to rotate and or install new block off bearings.
And anyway, this engine will be removed in a couple months for a different one(Built internals,etc) We are just doing this as a precaution be cause the owner had a balance shaft belt snap on him a while back on a different car and the engine was toast.
honda-guy
40
Aug 2, 2015 07:37 AM
