Oil filter question.. MD,MZ,K&N?
Old Feb 17, 2004 | 12:55 PM
JT-KGY's Avatar
Ran out of few of the MD356000 filters I bought mid last year...
Dealers now tell me that I should be using MZ690116 filters...
Has anyone compare them?
How about K&N oil filters? Some said that they are physically
smaller than OEM's...
I did some searches on the board.. couldn't find any conclusion
on which to use...
https://www.evolutionm.net/forums/sh...light=MZ690116
Old Feb 19, 2004 | 02:48 AM
JT-KGY's Avatar
Anyone?
Old Feb 19, 2004 | 04:51 AM
DGS's Avatar
DGS
Re: Oil filter question.. MD,MZ,K&N?
Just yesterday I made some calls:
Baldwin Filters 1-800-822-5394 (7a-5p CT M-F)
The Baldwin web site translates MD356000 to B227, but the hotline recommends B1402, if you have the space for the longer filter. (3 5/8" length). The 1402 has a higher burst pressure rating. The B227 has a 20 psi bypass, while the B1402 has a 14 psi bypass (for when the oil is really, really cold, or if the filter gets clogged).
If you can't find a local Baldwin vendor, the Hastings LF240 is the same as the B1402. (Hastings is a sister company to Baldwin.)
Mobil-1 and Walmart SuperTech (and, I've heard, K&N) are all made by Champion Labs: Filter hotline: 1-800-882-0890
The Walmart SuperTech (ST7317) uses a "clicker valve" bypass built into the end plate, and uses a cellulose (paper) filter with some synth strands. Champlabs says it's a 20 micron filter. When I was at Walmart, they had the 7317 priced at -- get this -- $1.95. (What the hotline calls "consumer friendly")
According to the hotline, the Mobil-1 (M1-108) still uses the traditional spring type bypass, and uses a much higher synth strand count, and is rated a 10 micron filter, intended specifically for synth oil.
I didn't ask about the K&N.
I have a Baldwin on my F-car (using Agip semi-synth oil), due to the need for a stand-pipe in a vertically mounted filter, but I'll probably go with the Mobil-1 filter on my EVO. (Presuming the price isn't too high.)
But I'm not about to pay over $20 for a Mo-1, when the $2 Walmart SuperTech isn't all that much less of a filter, and is just about as good as "the OEM filter". (Denso, I think.)
The consensus everywhere I've seen is to stay far, far away from Fram. Back in the '60s they were good filters, but these days, they're a disaster. Tons of reports of collapsing elements, clogs, non-functional anti-flowback valves, etc. The shop that tried to put a Fram on my 328 doesn't get to work on the car, anymore.
Old Feb 19, 2004 | 06:46 AM
oguratevo's Avatar
I also ran out of the MD oil filters. I used K&N HP-1004, its bigger and almost the same size as the MD oil filter.
Old Feb 19, 2004 | 12:28 PM
JT-KGY's Avatar
Thanks guys... I might checkout that Walmart filter...
As far as K&N filters... how much do they go for?
Btw.. here are some comparison pics of MZ vs MD that someone
post... their direct link was bad so I put the pics on my image
server...
More pics:
http://www.pbase.com/jt_kgy/evo_oil_filters
Old Feb 19, 2004 | 12:37 PM
sophis's Avatar
Been using both the Mobil M1-104 and the K&N HP-1004 for around 8000 miles and some road racing as well. Both have been holding up fine. Bought the K&N oil filter at Kragen for $9.99
Old Feb 19, 2004 | 01:06 PM
oguratevo's Avatar
I got my K&N Filter HP-1004 for $8.99 from 4wheel auotparts store.
Old Feb 19, 2004 | 01:38 PM
bluevilevo8's Avatar
mobil reccomends m1-108, not 104
Old Feb 20, 2004 | 01:30 AM
JT-KGY's Avatar
Btw... a little OT here... has anyone try a product
named FilterMag?? I'm about to order the RA300 for
my EVO...
http://www.filtermag.com/catalog.htm
Old Feb 20, 2004 | 07:05 AM
Novtec1's Avatar
Veteran: Army
man i guess im lucky... the dealer here in OK had a whole lot of MD356000 in stock.... they told me those were the only ones they carried for the EVO. i bought 3 when i changed my oil....but the guy told me..you don't have to worry we got enough filters to change my oil every 2 weeks if i wanted to.....
Old Feb 20, 2004 | 09:12 AM
asdf's Avatar
Me too. No probs. I like it because it's bigger, but like DGS and blueevilevo8 said, the "proper" filter is the M1-108. The K&N HP-1004 is the same size as the M1-104, which is the same size as the filter that came on the car. Now, all of a sudden, Mitsu calls for some tini tiny filter so it can have a higher burst pressure and still be cheap. I could care less about OEM filters and part numbers because these forementioned filters will trap smaller particles and have sturdier construction. If champion labs made an AC Delco Ultraguard Gold filter that would fit, I'd be using that. Only the best for my Evo
Old Feb 20, 2004 | 09:18 AM
asdf's Avatar
my EVO...
Look interesting. I wish it would work on dirt and other particles too.
Old Feb 25, 2004 | 03:04 AM
JT-KGY's Avatar
Re: Re: Oil filter question.. MD,MZ,K&N?
DGS,
Whats the micron rating for oem filters? I wonder...
Old Feb 25, 2004 | 06:45 AM
DGS's Avatar
DGS
Re: Re: Re: Oil filter question.. MD,MZ,K&N?
The Denso web page doesn't say. But the Champ hotline implied that the cheaper SuperTech was about as good as the OEM filter.
Different filter manufacturers use different test procedures, so the "micron" ratings are more useful to compare filters by the same manufacturer than to compare across producers, unless you can find tests done by an independent tester, rather than by by the filter maker. Baldwin rates their filters 23 microns. ChampLabs may be using a flattering rating procedure. (Although I've seen other filters claim 1/10 micron.)
The M1-108 was $11.99 at AutoZone. The 7317 was $1.97 at Walmart, but is sized more like the M1-110 (which was also priced $11.99 at AZ).
The M1-108 looks like the pictures referenced in your link. The 110 and SuperTech are a bit longer, but the same diameter. (They were out of M1-104s)
I'll probably put the M1-108 on the car, but the SuperTech is cheap enough to have one to toss in the "kit" box in the trunk. (The "Justin Case".)
Old Feb 25, 2004 | 08:42 AM
kimletrim's Avatar
Registered User
Some have posted that the Mobil M1-110 should not be used in our cars and the one that should be used is the 108. Some others have used the 110 with no problems and I don't see why it would be. The 110 is longer than the new Mitsu filter and the 110 is what goes on the 2g Eclipse 4g63s as well.
