Going into Gear issue
^ They installed it, but I'm no longer in the San Antonio area unfortunately, otherwise they would help, they were nothing but helpful to me. Only test I haven't been able to do is the clutch drag test, well just not at 7k+ rpms. The shifting in neutral problem is getting better, I will do more adjustments when I can, but I am driving across the country at the moment, car is holding together thus far, haha.
OK, not sure if this will help or not but if you can eventually get it into gear (clutch in) and the car doesnt stall and it will stay in place (car doesnt start rolling with brake off and clutch in), then its not a clutch issue. secondly, if you can put it in gear with engine off but not when running then this sounds like a synchro issue (especially since you're blipping the throttle which would match the shaft speeds). at first i was thinking it might be just the first gear synchro but then you said it was with all gears so I could see where oil type comes up. Anyway, I haven't figured it out but synchros keep calling out to me... good luck
Z_Lancer_Man
15
Mar 20, 2018 06:00 AM
Fireescape
Jul 4, 2016 11:18 PM
