Evolution Cranks but doesnt start
Old Apr 25, 2013 | 01:51 PM
luislm21's Avatar
I have an issue with my evo. I used it for a few days. One Morning i tried to start the car, the car was cranking but unable to start.
I checked Spark Plugs, and everything is OK with the ignition.
Camshaft Gears have the correct timing.
There is Fuel Pressure.
what is the problem>??
Old Apr 25, 2013 | 02:22 PM
Ev0ikon's Avatar
Cyl pressure check.
Old Apr 25, 2013 | 03:23 PM
b16a95eg's Avatar
Check the 10a fuse under the dash, it should be the very first one in the fuse box under that little storage cubby if I remember right. It should be labeled IGN on the diagram
Old Apr 25, 2013 | 03:26 PM
luislm21's Avatar
all the fuses are Ok, how can i check Compression>>?? i rebuilt the engine recently
Old Apr 25, 2013 | 03:29 PM
joseph143's Avatar
Double check the fuses... There are 2 under there... Also do you have pressure pressure or residual pressure in you fuel system... Check to make sure your knock sensor iac and crank position sensors are all working... All three will shut the car down
Old Apr 25, 2013 | 04:45 PM
MyronGainz's Avatar
This.
My money is on a dud sensor, or it not being plugged in at all.
Old Apr 26, 2013 | 07:25 PM
luislm21's Avatar
howw can i check those sensors?
Roen
11
Oct 25, 2014 09:53 PM
Viikduhh
Sep 30, 2014 05:31 PM
VKEVO
May 21, 2014 09:55 AM
batty200
Apr 22, 2014 05:11 AM
ozrallyzombie
Lancer Troubleshooting
Feb 19, 2014 05:46 AM
