lower timing belt cover removal?
Is there an easy way to remove the lower timing belt cover? Think I have an oil leak in that area but doesn't look easy to slide off with the engine in and can't find all the 10mm bolts to loosen it. Thanks.
You have to remove the crank pulley and some other accessory pulleys. Just find a DIY on timing belt replacement for a more indepth directions. No offense, but if you having difficulty removing a cover then you might be in over your head...
Remove upper timing cover (4 bolts)
Remove accessory belt and tensioner
remove crank pulley
remove water pump pulley
support motor under oil pan with jack (put 2x4 in between)
remove ps engine mount
lower engine to remove idler pulley (can't remove bolt until it clears frame)
remove lower timing cover bolts and extract cover
It should take no more than 1 hr to remove. Post what you find in terms of leak source
remove crank pulley
Ramatzio
Oct 10, 2016 06:55 AM
FS[South]: WTB lower timing belt cover
Yamahar1
Nov 24, 2015 11:17 AM
marinejensen
16
Jul 7, 2015 07:18 AM
anthonypazsd
Jan 31, 2010 03:01 AM
