6266 twin scroll
Old May 8, 2013 | 02:05 AM
tzoyi's Avatar
6266 twin scroll
I am building my engine(2.3) and I am planning to take 6266 turbo t4 twin scroll but I don't know what a.r to take,,my car is for street drive and I don't want much lag.if I put ar.84 maybe I have problem with the top end?
Old May 8, 2013 | 03:12 AM
17pstockcar's Avatar
I think going t4 with twin scroll you are looking at going with the 1.15 ar
Old May 8, 2013 | 12:40 PM
tzoyi's Avatar
1.15 it doesn't much laggy? it would spool like t3 .82 or earlier?
Old May 8, 2013 | 01:24 PM
JohnBradley's Avatar
1.15 spools like 60% of its size and makes 83.3% the power of the size relative to a single T4.
E.g. - 1.15 x 0.6 = 0.69 for spool, 1.15 x 0.833 = 0.96 for power.
I did a 2.0L VIII yesterday that was 28psi by 5000 with this exact combo and a really underwhelming sheet metal intake.
Old May 8, 2013 | 04:15 PM
mitsubeastlee's Avatar
thankyou for that equation, twinscroll all the way!
Old May 8, 2013 | 06:28 PM
car_nut15's Avatar
I will be picking up a 6266 Twin scroll ETS kit very shortly with a 1.15 a.r
Old May 8, 2013 | 08:01 PM
Faisalm's Avatar
So would you always suggest a twin scroll rather than a single scroll?
Old May 8, 2013 | 09:24 PM
jmcmill3's Avatar
i definitely know what my next setup will be.
Old May 9, 2013 | 02:33 AM
tzoyi's Avatar
thank you very much for the help..
Old May 9, 2013 | 04:24 AM
el.guerrero's Avatar
Can you please post some dyno/data on boost?
Thanks aaron
Old May 9, 2013 | 08:20 AM
ETS Michael's Avatar
I really like the 1.15 a/r. We are actually building a kit that's looking to max a 6766 with a 1.32. Any questions, don't hesitate to ask!
thanks,
Michael
Old May 9, 2013 | 05:21 PM
If it is in your budget, yes. The reason I made sure to mention that SMIM is that it killed spool on a car with a 2.3 that it had been previously installed on. It is basically like pulling 300cc out of the car on a non twin scroll kit. The main reasons for twin scroll (when sized right) is response time to full boost, maintaining spool between shifts (transient response and recovery time), and reduced backpressure which helps keep knock away.
For sure
Thanks aaron
I will go grab them off the dyno and try to find a single scroll 6266 to post it against.
Aaron
Old May 9, 2013 | 05:33 PM
So in looking at it it really isnt a good example. I am going to get the owner to remove that egregious intake manifold and go back to stock so we can get a good comparison. The Forced Performance HTA3852 we did in twin scroll not too long ago gives a better indication of a properly sized housing and the response you can expect-
https://www.evolutionm.net/forums/ev...l-hta3582.html
Old May 9, 2013 | 05:58 PM
EvoDan2004's Avatar
twin scroll for life. i agree as well 1.15
Old May 10, 2013 | 08:40 AM
M8NSTER's Avatar
Hey that's my car! Twin Scroll FTW!
