View Poll Results: Do you have/Have you had problems (CEL's) with the HKS RS intake?
No Problems at all with stock ECU
21
72.41%
No Problems at all with modified ECU
13.79%
Problems with stock ECU
6.90%
Problems with modified ECU
0%
Problems with both ECU\'s
0%
Problems with stock ECU, but solved with modified ECU
6.90%
Voters: 29. You may not vote on this poll
HKS RS Intake, Stock ECU, CEL ?'s!
I hear some people say that you shouldn't get an intake without flashing the ECU because an intake alone makes a dramatic difference on the A/F ratio which creates a lean spot somewhere in the A/F. Anyone agree with this? I personally haven't seen any solid proof for this.
I have been running the HKS RS for 12000k and not one problem yet.
Originally Posted by GreedMOTO
I have heard the rumor too, but my a/f on the stock ecu went leaner at 5k, but still good.
Here is a whole thread where I do a "case study" on the effect of intakes
https://www.evolutionm.net/forums/sh...d.php?t=110456
Sure the car still works with the new intake and without any tuning - BUT - is this how you want your car to run ?
OR - would you prefer this . . . . (same car after reflash tune)
DynoFlash - You are gonna get my ECU soon...you just scared the crap outa me with that post!
Does anyone have 272 cams and the RS Intake? Mine idles like sh*t and sometimes stalls. It was idling great with the 272s BEFORE the intake. Installed the intake and the idle now hunts/surges and runs lean. I've checked all the clamps and everything is tightend down. Air/fuel will be 13.XX one moment, then leans up to 19.XX. Up and down, up, and down.
I did scuff up the honey combs inside the MAF during the install. Will have to swap to one that is not scuffed up to see if that's what is causing the problem.
Other than that, the car runs great at WOT.
