Cam gears or no cam gears..
Old Feb 19, 2004 | 09:02 AM
rubelcon's Avatar
Question Cam gears or no cam gears..
I am purchasing cams this week, want to go with the 264/264, as I hear they have more meat in the 3-4k rpm range then the 272's which you really feel after 7k rpm..
? is, should I chance more drivetrain problems/issues and go with adjustable cam gears? or will I even notice the cam hp increase without the gears?
Any suggestions on cams and gears would be appreciated
Feel free to chime in David B..
Thanks!!
Old Feb 19, 2004 | 03:38 PM
timzcat's Avatar
Re: Cam gears or no cam gears..
Thanks!!
David will tell you No. It's a waste of money really, especially for the relative gains needing repeated tuning on the Dyno to get them.
Old Feb 19, 2004 | 03:40 PM
bovbilly's Avatar
do it. if anything, they look cool!
Old Feb 19, 2004 | 03:42 PM
timzcat's Avatar
They don't look to cool when they slip and take out the valves.
Old Feb 19, 2004 | 03:50 PM
Toddevo 8's Avatar
I just put in the 272 and can really feel the difference. also not as rough at idle as some say.
Old Feb 19, 2004 | 04:02 PM
tama_mog's Avatar
save the $$ and do valvetrain upgrade with your cams, not necessary but gives u higher redline and greater dependability...I think it's been agreed upon that the stock evo valve springs suck =O
Old Feb 19, 2004 | 09:44 PM
evo542's Avatar
with or without the wheelies? btw I don't think you need them to idle the car, the ECU (flashed) or piggyback should do the work....just curious
CannabisEvo
15
Oct 22, 2008 05:13 PM
evouser12
13
Jul 14, 2006 11:53 AM
Evo23IG
Dec 19, 2004 03:33 PM
titaniumkingpin
11
Nov 29, 2004 01:43 AM
