Throttle body question
Old Feb 19, 2004 | 02:44 PM
dryad001's Avatar
I was looking at the throttle body and all the stuff that is hooked up to it and something caught my attention. It looks like the throttle body has coolant running through it, correct?
If it does that brings me to some questions. Why does the TB need coolant going through it? Wouldn't it just warm the air back up after the intercooler?
I'm guessing it has something to do with emissions, but since I will never take the car through that is there anyway to bypass this? It looks fairly simple. Just wondering if anyone has done this or thought the same thing. If not I will be the first one to try this I guess and will post the results if there are any.
Mike
Old Feb 19, 2004 | 02:47 PM
bluevilevo8's Avatar
Re: Throttle body question
Mike
Yup
I'm sure there is a way to bypass it, as us fbody guys have been doing it to our ls1's as one of the "free mods". The gains would be minimal though.
Old Feb 19, 2004 | 02:55 PM
dryad001's Avatar
Re: Re: Throttle body question
Originally posted by bluevilevo8
Yup
Thought so... I did the same thing to my ZX and it had really no affect either.
Old Feb 19, 2004 | 05:10 PM
Speedlimit's Avatar
Admin Emeritus
Mike
It is to prevent the throttle body from freezing. If you live in cold climates, then you should not bypass. The gain is minimal (2 to 3 hp and a little faster throttle response) and not worth the hassle for most warm climate Evo's.
Speedlimit....
Old Feb 19, 2004 | 05:44 PM
Sunder's Avatar
I heard the anti-freezing thing in cold weather too.
I used a Hondata Insulating gasket for my S2000, and I heard rumours that Hondata will make one for any car, if you send them the original gasket.
Might be worth a shot?
It made a difference only in start/stop traffic for the Honda. There were no measurable gains on the dyno, but then again, the dyno doesn't simulate standing still in traffic.
Old Feb 20, 2004 | 03:11 AM
Fourdoor's Avatar
OK people, it has nothing to do with freezing or with emmissions!
The throttle body has a Fast Idle valve that is basicly a wax plug. When cold the wax contracts alowing an air passage to be opened up giving you a lot of air flow in cold conditions for a fast idle during warm up. As your coolant gets warm from idleing the coolant running thru the throttle body warms up this wax plug causing it to expand and block off this extra air passage. At this point your idle speed drops off toward normal.
Keith
Old Feb 20, 2004 | 07:56 AM
Wax plug? That doesn't sound too reliable...
Thanks for correcting our stupidity
Old Feb 20, 2004 | 09:42 AM
Fourdoor's Avatar
You are correct, it ISN"T reliable What did you expect from Mitsubishi?
They tend to either dry up with age and not seal giving your a permenently high idle.... or get gummed up and stick closed giving you a slow idle when cold. In general, they suck! But they are cheaper than making a larger motorized bypass valve. The small motorized bypass valve we have is only large enough to compensate for idle changes due to load such as the AC compressor and power stearing demands.
Keith
awdordie
28
Feb 20, 2016 01:09 PM
DSMolition
Jan 31, 2016 11:15 AM
Boombox
32
Jan 23, 2016 02:34 AM
bnr34rb26dett
Oct 13, 2015 06:14 PM
musca999
May 10, 2006 09:17 PM
