Cam seal install not going so well.
Old May 21, 2013 | 08:17 PM
srivera2010's Avatar
So im installing new cam seals. I have put a thin amount of rtv on the grooves and the seal itself. When I tighten down the cam cap the bottom trys to pop out. Any tips, suggestions, etc? Cant even get 5 ft lbs on it without it popping out.
Old May 21, 2013 | 10:11 PM
CaliCruiser559's Avatar
Any pics?
Old May 21, 2013 | 10:25 PM
Czarcasm's Avatar
Isnt one bigger than the other? Pics please like ^ said
Old May 22, 2013 | 06:31 AM
batty200's Avatar
Make sure the seal is seated all the way back against the head. If it pops out you ma be using the wrong seal. Is it an OEM seal?
Old May 22, 2013 | 08:18 AM
PureDrivePerformance's Avatar
+1
One time I use FelPro and it didn't fit as well as the OEM seals I use now. Like batty said, make sure it's up against the head.
Is it snug on the camshaft or loose?
Old May 22, 2013 | 09:45 AM
Snug, and OEM. It doesn't pop out completely but the top seems to sit in better. I have evened it in there still wants to move a little I will see if it moved out as it sat overnight.
gearheadvr4
Lancer Tranny/Drivetrain Tech
Mar 15, 2016 10:16 PM
lostsoulsevo
Aug 6, 2012 07:24 AM
rstchris
28
May 10, 2012 10:13 PM
bayrider
Nov 25, 2008 01:15 PM
stryfetew
16
Sep 26, 2008 12:46 PM
