HELP! Broken driveshaft carrier bolt
Old May 24, 2013 | 06:56 PM
sinstr's Avatar
Hey,
I'm after some urgent help! I am in the process of replacing my drive shaft carrier bushings and the bolt snapped.
Can anyone let me know what I need to do?
Old May 24, 2013 | 06:59 PM
hiboost2.0's Avatar
Which bolt? Snap a picture of it if you can.
Old May 24, 2013 | 07:15 PM
sinstr's Avatar
Old May 24, 2013 | 11:40 PM
matrho2792's Avatar
Can you get a set of locking pliers on it? If not you may need to use an extraction bit to remove it. Make sure and put a little bit of PB blaster to help break it loose.
Old May 25, 2013 | 05:17 AM
sinstr's Avatar
Yea I have no problem accessing the thread seen in the photo, but the head of the bolt is inside part of the chassis so not accesible.
Does anyone know how I can go about replacing it or anyone had a similar issue to this???
By the looks of things I will have to get the car trailered and a new bolt welded into the chassis
cficare68
23
Feb 19, 2021 11:09 PM
marksae
61
Aug 13, 2017 12:30 PM
gidz
Jan 9, 2013 05:27 PM
polish_pounder
Aug 30, 2011 08:34 PM
Carrier
Lancer Engine Tech
May 12, 2007 11:34 AM
