GSC Power Division R2 Cams
Hello all,
Trying to see if anyone is running these cams stock block 2.0? I know GSC does not recommend them due to the higher lift and shorter duration and says they are for stroker motors but what I am wondering is if they will physically work without piston to valve interference. Thanks in advance.
Thanks for the post but I am aware what Power Divisions says, I have an email from them. I am asking if any member with a stock 2.0 has used them. As we know doing things that others have not have led to discoveries of making more power. Just exploring
Yeah, but as they have stated the valves WILL hit the pistons with OEM pistons.
I'll find out the answer to this question in the next few weeks. I have a set of R2's to install, along with some 5041 springs and retainers and some GSC valve seals (and h11 headstuds and fp black). This stuff will be installed in a stock 9 head and piston set and was bought on the recommendation of Tom at TSComp, who insists there won't be an issue. With that in mind I'll be checking the seal/retainer clearances and probably valve piston clearance with clay. I'll let you know how it goes.
Posted from Evolutionm.net App for Android
please share your findings, I believe the clearance will be close but I dont think they will contact. Ideally I would like to seem them on a stock bottom end but at this point any comparison is better than none. From the spec on these cams I think there is some power to be made!
dont know about the r2's but gsc has been known to be very conservative when rating their cams. im running GSC S3's on a stock 2.0 with a stock 8 turbo with zero issues. i would contact english racing to get a 2nd opinion since they seem to use/sell alot of gsc cams.
