Leaking Synapse Bov
Old May 28, 2013 | 10:46 AM
jameswwt's Avatar
Leaking Synapse Bov
Hi, just wonder can a re-circulate help/solved leaking bov?
As my response is effected.
Thanks
Old May 28, 2013 | 11:00 AM
deylag's Avatar
There is not enough given information for us to help you out. What is your setup? Recirculation or Speed Density?
How do you know that the BOV is leaking? Did a boost leak test show that it is leaking?
Did you try replacing the rubber o-rings in the Synapse?
Old May 28, 2013 | 12:34 PM
GregM's Avatar
It will be SD. Mine leaks too at idle, but not when doing a boost leak test.
Old May 28, 2013 | 06:22 PM
jameswwt's Avatar
Hi Deylag, ive tested by using a plastic bag to cover the bov vent port and its inflated even on idle.
Yes, im running SD and VTA.
No, i did not replace the o-ring yet as i though its quite new.
Thanks and currently my response seems slower than previous.
Old May 28, 2013 | 06:25 PM
jameswwt's Avatar
Thanks GregM
Old May 29, 2013 | 06:18 PM
jameswwt's Avatar
Just wonder is there Synapse representative here as i never get their reply at all after emails sent to them regarding my problem and purchase inquiry.
Really frustrating.
Alexevo09
May 10, 2015 02:33 PM
brakeboost980
Apr 5, 2012 12:21 AM
Fast_Freddie
20
Oct 15, 2008 08:28 PM
w8lifter21
May 31, 2008 06:24 AM
sirloin1219
16
Feb 8, 2006 08:51 PM
