EVO missing on #1 and #3 cylinders only running on 2 cylinders
Today I pulled the roller rockers out and the lifters on the intake side and did the leak down test on all 4 cylinders. The outcome is that #1 is leaking off 37% through the intake mani and the rest of the cylinders 2-4 are below 5% and are good no issues. All cylinders were tested to the max for the leak down tester I have and that is 100 psi. I called BR to find out my next plan of action and was told I should talk to David Buschur and that he wouldn't be back to the shop until 4:30pm ET, so I will call in the morning to talk to him and find out the plan and what to do from here.
Last week I was able to meet up with one of the great EVO tuners and specialist here in CO, TOBZ. The head is fine and valves probably just need to seat more. What I did find out and not sure how and why I was doing this but I was installing the plug wires backwards. I have the OEM coils and wires and was using the wire from #2 to #1 and #4 to #3. I know #4 goes to #1 and #2 goes to #3. This was the relationship between #1 and #3 not firing as the spark was happening just not at the right time almost as if it was 180 out on the timing. I feel kinda dumb but it is what it is and I will never forget this.
I have ordered a new head gasket from STM Tuned on Monday and got overnight shipping and have been getting everything ready and assembled. I will get the head gasket tomorrow and hope to have the car started and running and seating the piston rings Thursday!
Hopefully you get some partial refund to have the valves reseated. I dont know how that was not found when it was tested.
On heads that I used to do, we would make a rubber gasket and bolt it to a steel plate/table and leak down each cylinder with shop air to verify that the valves are seating/sealing properly and we can see how much is leaking down.
Got my car put back together, started and brought her home today!!
http://s235.photobucket.com/user/thi...af0fb.mp4.html
haha Thank you! i just bought my 8 a week ago and decided to take the valve cover off and thought i re-installed everything correct , i was having the same issues and was very stumped!! lol thanks for posting this!
Awesome!! I'm glad this helped I know I'm not the only one that has ran into this before and it is confusing at first and then it's like duh why did I overlook the obvious. Congrats on the new EVO hope you like it!
I had same problem with my Evo 6 TME, cylinder 2 was suddenly missing. After some check I found out there was a broken resistor pack for one of the cylinder. 3 pieces was having the same ohm but the last one was blow off.
But very interesting forum, this help me a lot to find this problem myself. Thanks
BobbyB13
Sep 27, 2017 06:04 AM
