4g64 timing help!
Old Jun 13, 2013 | 09:00 AM
90zcrex's Avatar
Originally Posted by babaz7
sir if i move the timing dot to line up with the valve cover mark, the key hole mark beneth the timing dot will move with it aswell...
will the timing be not out again?
Yes, he is incorrect. You have it timed correctly.
You just have to think of it this way, The ONLY thing you are accounting for is the change in the length of the belt from the crank to the cam.
All you have to do is make sure the actual cams are straight up like factory. You do this by setting the middle mark on the cam gears to the mark on the valve cover. It doesn't matter where the indention is on the cam gear as all you care about is that the Cams and Crank are lined up.
The 3.75* thing is kinda stupid cause all engines are different, if you line the center mark up with the valve cover you are correct.
Old Jun 13, 2013 | 12:00 PM
evolve_VIII's Avatar
My bad. I was comparing to my engine when i looked at the pics. You are correct with setting the cams at 0*. Line up the inner mark with the valve cover. This is because I truly advanced my cams to get the most out of them. Since my engine is already running, it set the cams with the timing at 0* meaning the dots lines up with the cover. Then the cams were set 3.45 degrees advanced.
What cams are you running?
Old Jun 13, 2013 | 08:24 PM
babaz7's Avatar
i have gsc s2's
Old Jun 13, 2013 | 08:25 PM
babaz7's Avatar
and thanks everyone for their input!
Old Jun 14, 2013 | 05:21 AM
i have gsc s2's
You are probably going to advance the cams a few degrees to get the most out of them. With the 2.1, that thing can spin to 10K safely (with all the supporting mods) but this will also help spool depending on your turbo.
Old Jun 14, 2013 | 11:48 AM
wreckleford's Avatar
The Advance and Retard markings are wrong on those gears btw.
Old Jun 14, 2013 | 09:56 PM
babaz7's Avatar
how are they wrong?
Old Jun 15, 2013 | 04:22 PM
browningderek's Avatar
+ and - are on the wrong sides. Take a pic so we can see the cam gear dowels and which way they point.
Old Jun 15, 2013 | 09:27 PM
babaz7's Avatar
they are pointing upwards, are they correct?
Old Jul 3, 2013 | 08:18 AM
Mauricio Evo IV's Avatar
Hi man, I ask some question in your 4g64 biuld thread. I have the same problem like the OP. I use a 4g64 blocj and build 2.1.
My question is, with the complete engine mounted in the car, can Iuse the deegree wheel for set the cams? I ask this because, like you say before, every car is different, and I resurface the head .020 and use cometic head gasket, for that i canīt only retard 3.75* de gears.
evolve_VIII
444
Dec 16, 2020 08:11 PM
Eno-Evo
14
Aug 4, 2015 08:36 PM
Blue91lx
98
Apr 29, 2013 04:07 PM
Blue91lx
45
May 3, 2012 02:47 PM
evoyrrah
23
Jan 22, 2011 02:22 PM
