Clutch Fork Rod Help
Im doing a Comp Stge 4 install, and this is the worst install I've ever come across.
I am trying to remove the clutch fork and the rod/dowel that goes thru it that usually slides out but it does not want to come out. I can hammer it downwards but cannot bring it up to pull thru the freeze plug. Do you guys have any suggestions or tips to pull it out of there?
I had the exact same problem last night, ended up hitting rod down to, lowest point then cutting it with a dremel and cutoff wheel. It took a while but it worked. Stm sells the rod for 27 bucks. Just make sure you clean the spot for the rod with sandpaper or something because the likely issue is a chewed up spot for the rod
Biggest hassle ever
drionbh3
Evo X How Tos / Installations
Mar 13, 2017 06:58 PM
FS[Northeast]: 88mm Manley Crank, Tial 44mm MVR WG, Tial 50mm BoV & more
Xtsy
Aug 19, 2015 07:10 PM
Xyster the 1st
Dec 7, 2014 06:25 AM
Xtsy
17
Jun 6, 2014 11:10 PM
