Need some ideas on why I'm spooling slowly
Old Jun 21, 2013 | 07:53 AM
  #61
aggieEVO's Avatar
Here's where I think it's leaking. I couldn't check, but something feels loose when I tap my finger on it. Thanks to mil spec for the picture.
Old Jun 21, 2013 | 07:57 AM
  #62
WRC-LVR's Avatar
Originally Posted by aggieEVO
Started to have some success. I bought an air hose connnection on my way home. Pulled off my old valve stem connection and installed it with some rtv and epoxy. Rush job. Hooked it up after letting it dry a couple hours. Cranked the pressure up to about 10psi. Immediately found a pretty big leak from the hose that runs to the BOV from the UICP. Turned off the air, patched it up. Notice the BOV itself was leaking. I thought someone had told me to pull the line from the BOV. I guess that was incorrect. Put the vac line back on it. Plugged in the compressor. POP. Tool came apart. Tried several times and the cap kept slipping out of the coupler. I mixed up some epoxy and it's curing. Maybe this weekend.
Before my tool because useless, I found a leak at the throttle body. Couldn't pinpoint it, but I know it's there, now. I ruled out several places, too. All my small vac lines seemed fine. Intake manifold vacuum line connections were fine. FPR vacuum line was fine. The coupler by the air box was fine. I'll start up the hunt again when I can.
THIS is a much better way to hunt. Just pressurizing the system with an air chuck was not good for a one man show.
I had a suspicion about that UIPC to BOV connect. none of the OEM clamps hold there well and many of the t bolt replacements do not fit well..
Just took my tester out of the bottom of my tool chest. I used a ball valve connector from home depot to slowly crack the line pressure to the tester. Used a long metal 2pc valve stem on the plate at the turbo so i can get a pressure reading from an accurate gauge.
Then you are not going to believe this, but Napa used to sell plastic ashtrays bigger on top and smaller on bottom. $3 fit the flex pipe to the TB perfectly. thick plastic as well. I did get a large t bolt clamp to hold it as yes when i ramped it up it blew off fast. Flew right by my ear...finally cranked it up and like you found leaks all over.
Here is what i found plastic BOV leaked from all seams and past the diapraghm seal. UICP pipes leaked badly to the BOV. BOV leaked badly to the turbo inlet hose. TB coupler leaked ( rough spot on one side, badly installed...used heat gun to soften and fix. ) Turbo outlet pipe had leak from one screw. All the couplers leaked minorly even with t bolt clamps until manually adjusted under pressure. UICP coming up from the IC badly installed as well...same fix as the TB coupler,
I did mention to block off the vacuum hose at the BOV... Listen and then un clamp it , if you hear any extra leaks on unclamping, the diaphram is shot or the housing or gasket is leaking assuming the vacuum line is zip tied
Symptoms include slight drivability issues in/out of steady throttle bucking etc
Im lookin g forward to hearing that you can boost quickly and hold 21-17 psi after all your hard work..Great job man..
Old Jun 21, 2013 | 08:07 AM
  #63
WRC-LVR's Avatar
So yes, 4 leaks so far.
1. UICP to BOV hose
2. EGR blockoff plate
3. BISS
4. Something else on the throttle body
I just ordered a new BISS, o-ring, and ICV gasket. Should be here Wednesday.
I'm trying to figure out the last leak on the throttle body. It's not the seals. It feels like it's coming from the bottom bolt on the TB closest to the firewall. I'll figure it out. The only thing I didn't really check was my intake manifold to head. Hopefully it's fine. I used 2 brand new gaskets with my phenolic spacer.
So the question is, would these 4 leaks cause 1000-1200 rpm of slow spool?
You will find out after fixing all the other issues you have found ad are fixing..
Put a straight rule on the Manifold at the TB to ensure flatness and cross check it several ways..that will leak under vacuum and boost.
I would ask Mil-Spec about the possible cause for the leak from the TB pic there.
The phenolic spacers .. are those from the manifold to the head? Not a fan at all of those. Most are not machined exactly flat and the gaskets may not seal well so leaks after the charge system.
Principle is ok, just not much to gain at all from it..
Old Jun 21, 2013 | 09:13 AM
  #64
aggieEVO's Avatar
Thanks again for following along and helping me with this.
It's a Grimmspeed spacer, I'm hoping it was well made. I did a full delete on the EGR including plugging the head, so I'm hoping that the manifold will see some cooler temperatures. I figured I was there, I might as well.
I sent Aby an email. I'll share the comments.
If I can budget it, I may get some T-bolts next week to help with this.
Updates when I have them!
Old Jun 21, 2013 | 09:56 AM
  #65
aggieEVO's Avatar
Okay, so what I did was pull the hose off and plug the hose. I was thinking that the BOV might start to open. Well, with the BOV nipple OPEN, boost was coming through. With the hose back on, no air coming through. You were saying to pull the hose and then cap off the nipple?
Old Jun 21, 2013 | 06:42 PM
  #66
aggieEVO's Avatar
Dang... So I determined that the air was definitely coming from there. Removed TB. Removed screw:
That o-ring is shot.
Unfortunately, I lost one of the little half-moon pieces to the depths of my engine bay. Dangit!
Old Jun 21, 2013 | 07:03 PM
  #67
WRC-LVR's Avatar
No i mean pinch off the 3/8 "vacuum hose to the BOV..pinch on pich off use smooth jaw pliers or something
.So air comes out the nipple w/o hose. it really should not. it is sealed by the diaphragm in the bov canister. I am guseeing you cant heard the leak when the vacuum hose is back on.
OK that means the diaghragm is leaking . If the seal in the bov just lifts you will hear air going back to the turbo inlet thru the BOV as it starts to lift.
It can also mean the housing is leaking air past the diaphragm to the nipple. How many psi? My ix holds 23 easily w/o crushing so ...? Did you also say you found leaks on the ix BOV body as well at some point?
Well for now just get the t bolts and fix the major issues. Then you can either replace with new ix or synapse. Fixing what you have done will most def help the spool.
BTW I saw the pic you posted...that is ugly broke :-0 Maybe Aby has the part to fix and it will be cheap IIRC that is some sort of bimetallic spring for the water heater circuit to the TB to help keep it cleaner and provide a deicing function in winter
?maybe someone local as a junk TB that the bit is still ok they will let u have.
Old Jun 21, 2013 | 08:44 PM
  #68
aggieEVO's Avatar
Well, if I'm not running the coolant lines to the throttle body, maybe it won't matter.
The o-ring was really shot. I RTV'd it temporarily. I put it all back together. That little piece there is part of a 2 piece ring that goes around the shaft right below the spring. Probably keeps it centered. I also chanced reusing my TB gasket. A little RTV, again. I'm generally not a fan, but my local dealership doesn't keep anything in stock.
So, I think my only leak is the BISS screw, now.
Old Jun 22, 2013 | 08:50 AM
  #69
aggieEVO's Avatar
Well, it seems a little better. I think I'm getting boost before 4k, now, but not at 3200ish. At least not by my eye. I had another pound of boost from last time I set it, too. Creeping in 5th gear. I'll adjust the actuator rod when the car cools down. Probably just take it down a turn.
I need to fix my tool to hold better. It's not holding more than maybe 10psi without blowing apart. I'm sure there's something else leaking.
Old Jun 22, 2013 | 10:26 AM
  #70
WRC-LVR's Avatar
Boost will vary in different gears. Doing a boost test in 2nd will show 3600-3800 peak when going WOT at 2500 4 th or 5 th gear will peak faster 3200 most likely w/o much leaking. typically I set mine at safer road speeds on 2 nd or 3rd then tune the tables for less boost( less WGDC ) in 3-6 gears
Look for sparky's threads on setting th WGA properly and determining boost creep in this section. Very helpful.. He may respond if yu pm him as well.
I d o feel for you so many issues and bits broke...chin up though...once the car gets sorted it will be something to be proud and very fun to drive
respects,
Milburn
Old Jun 22, 2013 | 10:32 AM
  #71
WRC-LVR's Avatar
Napa and other partsplaces sells gasket material by the sheet or roll. get one of the older guys to dig in the catalog....Cut to size and use a rubber mallet to get the holes and indents properly marked...use razor or exacto knife or sharp box cutter to trim carefully. Gently roll against the curl to flatten. re-assemble and grin :-)
Old Jun 22, 2013 | 05:04 PM
  #72
aggieEVO's Avatar
I did another boost leak test. Got my tester to hold, too. Yay! Pumped 15psi and held. Couldn't find any leaks. I'm really happy about that. Slapped it all back together. Feels like it's running great. So happy. I'll do a log as soon as I can.
Thanks again for all your help on this.
Old Jun 23, 2013 | 06:43 PM
  #73
WRC-LVR's Avatar
You are most welcome , sir. Is the boost full at 3300-3600 now? On to tuning. !!!
Meanwhile ...enjoy and spread the word how to really diagnose the Charge air system
GL
Old Jun 30, 2013 | 07:39 AM
  #74
aggieEVO's Avatar
Just an update, the car is running really well! I re-gapped the plugs to .025 last night and it seems to run even better. I'm really happy with the car right now. I have some things to address, but that's for my other thread.
Thanks again for all the help. So nice to have the power come on early and consistently!
Old Jul 5, 2013 | 12:35 PM
  #75
aggieEVO's Avatar
Well, I got a log done this morning. Got VD running and am left wondering what's going on... again.
I know VD isn't the end-all of dyno numbers, but it gives you a good visual on what's going on with the car. I only have one copy of a dyno from a stock VIII and it's getting peaq torque much sooner.
I'm guessing I still have an issue somewhere.
edsct9a
Apr 21, 2016 11:31 AM
mrm95
Nov 28, 2014 02:40 PM
aggieEVO
Jul 5, 2013 09:01 AM
zoso
15
Jan 2, 2011 01:39 AM
jberb55
27
Oct 28, 2008 02:27 PM
