misfire after rebuild
Old Jun 24, 2013 | 08:06 AM
pukka's Avatar
ive recently buillt an evo vi engine with evo v111 cams in my evo iv head and fitted it in my prior crankwalked iv.
its only running on 3 cylinders but i cant track down the fault.
compression is spot on and within 5 psi of each other each cylinder.
the misfire is cylinder one as i have no drop in rpm or misfire tone when i remove injector 1 plug.
i have a good spark on the cylinder. I can hear injector 1 ticking and it also has voltage on the plug.
when i remove the plug in cyl 1 after it running with misfire its slightly wet on the piston top and it smells like fuel but cant be sure. its not oil and not enough to effect the cylinder to zero % combustion.
my current ideas are
1)i have noticed that a previous owner bypassed the fuel pump relay on bulkhead and just joined 3 of the pins up but this worked before
2)injector resistor
3)old hydraulic tappets with new cams
4)faulty injector/blocked injector
what do you recon
Old Jun 25, 2013 | 04:39 AM
pukka's Avatar
i might swap the injectors round and see if the cylinder misfire swaps along with
Old Jun 25, 2013 | 11:13 AM
Biggy VIII's Avatar
Make a leak test on a cold engine. If one of the cylinders has a major leak - repeat the test with cams or rockers taken out. If there is no leakage anymore then it could be that your valve seats been machined and valve stems not, then they may not seal well.
X2jesse1x
Aug 8, 2017 05:51 PM
Enjoi926
May 31, 2017 06:47 PM
dillons13
Sep 2, 2015 06:25 AM
comatose721
Lancer Troubleshooting
15
Jan 11, 2008 10:28 AM
comatose721
Lancer Engine Tech
21
Feb 6, 2006 09:33 AM
