Turbo Heat Shield Re-Paint and Re-Finish
Old Jun 27, 2013 | 05:53 AM
Ridge727's Avatar
Hello Everyone, Just wanted to share a quick project I did on my car the other night. Picked up a used OEM heat shield for my Evo IX SE, and wanted to strip and re-paint it on a budget. From what I have read you need a high temp paint that can withstand 1200-2000 degrees F. I picked up a can of VHT Flame Proof Ceramic Coating in a flat red, as well as a can of Aircraft Stripper.
1.) step one involved coating the heat shield with the stripper and letting it sit for 30 minutes. The paint or coating they used on these shields from the factory is not your standard paint. Normally the paint bubbles up and basically falls off the metal surface, but this coating turned into a thick tar which had to be wiped off. I grabbed a towel and rubbed all the trated areas and then used brake cleaner to release it off the shield. I then did another treatment with the stripper to make sure I got as much off as possible.
2.) There were still some areas that i couldnt get all the paint off, so this where I decided to give it some "bench grinder love." I have a brass brush on my grinder and that did the trick, I went over the entire surface to give it texture for the paint to stick to.
3.) Light coats of paint were applied 5 minutes apart till completely covered, I let it air dry over night.
Upon inspection the next morning the paint was still tacky, the can of paint states that this paint must be cured/baked in an oven to withstand these high temperatures.
On the Vehicle
  • Paint must be completely dry before curing
  • Run at idle for 10 minutes
  • Cool for 20 minutes
  • Run at idle for 20 minutes
  • Run under normal operating conditions for 30 minutes
Off the Vehicle
  • Heat to 250°F (121°C) for 30 minutes
  • Cool for 30 minutes
  • Heat to 400°F (204°C) for 30 minutes
  • Heat to 650°F (343°C ) for 30 minutes
I will be following these steps Saturday in my house oven to see if I can cure this, and to find out if any smell is left in the oven and house after doing it....oh by the way the wife will be out of town , which is the only way I will get away with baking a manifold heat shield in the oven. I will post up my finished results in the next couple days, hopefully this will be a good affordable option for us weekend project guys out there on a budget.
Old Jun 27, 2013 | 06:14 AM
06MREvo's Avatar
I like the raw finish, you should have just put a clear coat over that....
Old Jun 27, 2013 | 06:34 AM
egis's Avatar
looks really good,sporty.is there any clear coat that can withstand T from exhaust manifold?
Old Jun 27, 2013 | 07:04 AM
gsx1992's Avatar
I'm interested to see how it holds up over time. Keep us updated!
Old Jun 27, 2013 | 07:36 AM
evo8426's Avatar
I don't like the red. It looks like one of those things where people go overboard on colors like in the interiors of some cars on this site.
I stripped the paint with steel wool then used High Temp grill paint to repaint mine black, stuck it in the oven for 20 minutes at 400* and it came out real nice.
Old Jun 27, 2013 | 09:01 AM
andrewzaragoza's Avatar
yup VHT Flameproof has a clear coat.
Old Jun 27, 2013 | 09:32 AM
Ridge727's Avatar
I will for sure keep everyone updated on the life of it, like I said I will be putting it in the oven Saturday. The red may not be everyone's choice but I figured I would just try it...May not be everyone's "cup of tea" but if I dont like it I will just strip it and re paint. Can you get me the part number of the clear coat from VHT? And will that clear also withstand the heat?
Old Jun 27, 2013 | 10:15 AM
evo8426's Avatar
Totally understand red isn't for everyone but you didn't half *** the work which makes it not so bad. I was just sharing my opinion on it, but I too would like to find a clear coat that will withstand the heat. Rain drops/water spots will make the paint look like crap really quick.
Old Jun 27, 2013 | 12:24 PM
Ridge727's Avatar
-VHT SP115 FlameProof Coating Satin Clear Paint
There you go, I will see about picking up a can of this to test out on the manifold. it says on VHT's website that the "curing" procedure is the same as the paint. It will be interesting to see if this application will help with cleaning from water spots and such as was stated above.
Old Jun 27, 2013 | 12:31 PM
DaRw1n's Avatar
This!
But I did mine in the same way except mine is silver and not red
Old Jun 27, 2013 | 01:25 PM
icrnk's Avatar
I just had mine coated in Titanium color when I had some other stuff being done
Originally Posted by DaRw1n
This!
Old Jun 27, 2013 | 01:41 PM
Ridge727's Avatar
That Looks Excellent! I like the silver, I just wanted to try a different color I havent seen. If I decide i dont like it I will probably strip it back down and polish the metal then clear over as previously suggested.
Old Jun 27, 2013 | 08:13 PM
YogSaahoth's Avatar
Veteran: Army
Been coating my heatshields this way for years. I use rustoleum 2000deg but I also use the vht satin clear over the top so I'm sure it works well. I cure them in the oven just cus it can fit. Just do it when the old lady is out of the house lol. The finish won't last forever...it will start to wear at the bolts since that's where it gets the hottest. Here's how mine looks...refinished it about a year before this pic. You can see it getting a little funky around bolts
Old Jun 27, 2013 | 08:28 PM
Craig King's Avatar
I recently upgraded to a Buschur ported and coated manifold and I removed the heat shield. I can't decide if I want to put the heat shield back on, or show off the Buschur manifold proudly??
Old Jun 28, 2013 | 07:10 AM
egis's Avatar
I'd say show it.OP the real question is does it smell while baking and does oven smell afterwords and for how long after the baking.cause I'm 100% sure my wife would not accept this so i might have to do it while she's out lol.thanks!
