Painting over Swain Tech
Hey guys. I just sent my exhaust manifold, o2 housing, and dump tube to Swain Tech to get the White Lightning put on. I'm not planning on it now but maybe in the future, to paint over the White Lightning if I ever get tired of the white look. I was just wondering if it's okay to paint over White Lightning?
hum. maybe you can. but IMO i would let it heat cycle a few times on the car. it is recommended and best to do this before you have it Swain Tech coated. i would assume after it is coated it would be best to do it again. make sure you coat evenly. otherwise you will notice the texture to vary.
my new setup will be a bit extreme. Swain tech mani, turbine, DP as always but ill have the DP wrapped and a DEI turbo blanket on the turbine housing.
i tried it last year but i put the turbo blanket on before assembling the turbo kit. when i put the oil return line on i must of pinched the blanket between the flange. well i am lucky i did not burn the car to the ground. the blanket absorbed a crap load of oil and i drove it around for about 25 miles thinking it was the typical smoke from installation that you sometimes see. i will be a bit more careful this time.
[FS] 6466 Turbo Kit
CT9Asphixyation
Sep 6, 2015 02:38 PM
MJ23FE
For Sale - Cars For Sale
49
Jun 6, 2013 06:21 AM
