fuel in oil
Old Jul 5, 2013 | 11:56 AM
cold6g72's Avatar
fuel in oil
Been getting a milky oil drain when I drain the oil. Fuel pressure is about 50 psi. I am unable to get it any lower with the fpr....would this fuel in my oil be due to my high fuel pressure....I was told that 50 psi was a workable pressure but if not how else would i get it lower
Old Jul 5, 2013 | 09:43 PM
barneyb's Avatar
Milky could be coolant.
Old Jul 6, 2013 | 12:46 AM
cold6g72's Avatar
new gasket....and it has an overwhelming smell of e85
Old Jul 6, 2013 | 05:34 AM
gsrboi80's Avatar
New gasket not torqued properly?
New gasket on but head and/or block surfaces not flat?
See where we're going here. Milky oil is most certainly coolant
Old Jul 6, 2013 | 11:18 AM
cold6g72's Avatar
block build by map, gasket was torqued properly... oil was fine until fuel pump was hotwired and pressure went way up...
and if coolant was it, i would get a drop in the level, but it stays static
Old Jul 6, 2013 | 11:50 AM
2slow4now's Avatar
If it is fuel in the oil I would be wondering if you have an injector leaking.
Old Jul 6, 2013 | 11:51 AM
gsrboi80's Avatar
Could just be my ignorance with E-85 as it is not available here so I have no exp with it at all
Have you tried adding it to oil externally? Does it turn milky?
I have read of more moisture/water getting into E85 vs gasoline. Maybe somewhere to look though I'd think the cars driveability would suffer at that point
Old Jul 6, 2013 | 04:54 PM
Frew's Avatar
Possible you are so rich you are washing the cylinder walls, seen it before, not on this platform.
gasolinebaptism
Mar 12, 2015 08:00 PM
WWJPD
Jul 2, 2013 11:35 AM
rodman
May 4, 2008 09:42 AM
wickdaddy
Lancer How Tos / Installations
Nov 9, 2006 10:31 AM
umiami80
25
Apr 22, 2005 05:32 AM
