driveshaft issues
Old Jul 8, 2013 | 09:32 AM
pukka's Avatar
driveshaft issues
im getting really bad outer cv joint noises from both wheels. ive replaced both joints and its still making the same noise. the joints did knock off and on the shafts really easily so i wondered if it could be the retaining snap rings not holding the shafts in the joints on full lock
i rang mitsi dealer and they said the shafts dont have retaining snap rings on the outer ends. is this correct?
evo iv btw
Old Jul 8, 2013 | 09:47 AM
pukka's Avatar
please see attached image
Old Jul 8, 2013 | 10:27 AM
pukka's Avatar
before anyone says, i have already checked my transfer box for snapped bolts
Old Jul 9, 2013 | 01:44 AM
pukka's Avatar
bump . anyone? guess i'l have to take a shaft out and look
Old Jul 9, 2013 | 08:18 AM
pukka's Avatar
well theres a groove there but its not very deep and i currently have no snap ring in it. should there be one ????
Old Jul 9, 2013 | 11:22 AM
barneyb's Avatar
No snap ring on the outer end, the joint at the wheel does not disassemble.
Old Jul 10, 2013 | 01:34 AM
pukka's Avatar
im working on the front shafts not the rears. pardon the diagram
Old Jul 11, 2013 | 05:42 AM
pukka's Avatar
anyone?
Old Jul 11, 2013 | 11:10 AM
barneyb's Avatar
I knew you were asking about the fronts.
Old Jul 11, 2013 | 11:32 AM
pukka's Avatar
oh rite ok. when you say it does not dissasemble what do you mean because i obviously have as i replaced the cv joints with genuine mitsi joints
Old Jul 11, 2013 | 09:45 PM
barneyb's Avatar
The boots are replaceable. The boot bands are released and the "C" ring and tripod are removed from the inner end. Then both boots are slid off of the inner end. New boots are the reverse of the process.
I don't know how the outer joint is assembled at the factory but I've not heard of it being replaced as a separate part in the field. If the joint is damaged it is cause for a new or rebuilt axle.
Old Jul 11, 2013 | 11:40 PM
pukka's Avatar
lots of people just replace the outer shaft. look here for instance.
http://www.camskill.co.uk/m8b0s2306p...olution_4_CN9A
even mentions the snap rring that mitsi say doesnt exist
Old Jul 12, 2013 | 11:07 AM
barneyb's Avatar
Okay, I just now see you drive a Evo 4. I searched the site you referenced for a 8 or 9 outer CV joint and all I come up with is a complete axle. So, the outer joint on your car can be changed. Good luck with your project.
Old Jul 13, 2013 | 03:41 AM
pukka's Avatar
i rang a different mitsi dealer and they wont sell me a snap ring they said they only sell complete shafts haha.
im gunna weld the ****ing thing on soon!!!! theres no way im paying ££££ for 2 little snap rings
CrAnSwIcK
May 20, 2025 06:21 AM
EGbeater
Aug 6, 2021 05:47 AM
Technical10
Jun 3, 2015 07:52 AM
pukka
Jul 2, 2013 09:48 AM
DisgustipatedM3
Oct 22, 2012 05:40 PM
