HKS Cam gears SETTING ? PLEASE HELP !
Old Feb 22, 2004 | 10:21 PM
JDM-Spec.com's Avatar
Hi,
I just installed my HKS cam gears with out changing the cams ? can someone give me the settings, I was told -5, -5.
I just want to make sure. can I set them at -4, -4 just to be safe.
PLEASE ONLY RESPOND if you know what you are talking about.
Thanks.
Talal.
Old Feb 22, 2004 | 10:30 PM
Smogrunner's Avatar
-5,-5 is fine. Here is a photo at -2. I did -2 because I have HKS cams. Use this photo for reference.
Attached Thumbnails HKS Cam gears SETTING ? PLEASE HELP !-smog-s-cam-gear.jpg
Old Feb 23, 2004 | 01:00 PM
Agent-Smith's Avatar
Can someone explain to me what this does for you?
Old Feb 23, 2004 | 01:04 PM
Eric Lyublinsky's Avatar
With out going into a large technical explaintion. It's like driving a S-2000 and hitting Vtec. In Vtec the cam timing is adjusted for more up top power.
Does that make sense?
Old Feb 23, 2004 | 01:09 PM
Not entirely - feel free to get technical i Can understand that.
Im a big DIYer and a computer programmer so i can figure most stuff out.
Old Feb 23, 2004 | 01:40 PM
Guys please discuss V-tech in another place, I got it on my acura and it just makes it louder past 4500 rpm.
I need a sure answer what to set my cams to ? before I make a $5000 mistake.
Are you all sure it is -5, -5, can I go -4,-4 just to be safe, I don't want the valves hitting each other.
talalhz@yahoo.com
Old Feb 23, 2004 | 01:45 PM
Az3ar's Avatar
ask some pro we are not really sure, just make sure befor you kill your valve and piston head, by the way i am getting the same exhaust you have how do you like it??? any power gain???
Old Feb 23, 2004 | 01:52 PM
^bump^
Old Feb 23, 2004 | 03:34 PM
evo542's Avatar
I think you should live it as stock, a lot of tuners say to leave the stock settings becasue HKS cams are made to be used without the cam pullies, either way u will still feel the extra power!
Old Feb 23, 2004 | 03:56 PM
stevEVO8's Avatar
He didnt install HKS cams; jsut the gears.
He is looking at changing the timing on the stock engine.
BTW how did you install just the gears? Did you completely retime the engine or did you remove one gear at a time and replace?
Thanks
Old Feb 23, 2004 | 04:14 PM
I had a local shop install them for me, since they had to knoledge of setting them, I told them to just leave them at zero, zero. I could set them my self that is the easy part. I was watching them struggle putting them in for over 2 hours, it was difficult. I just need the setting is it -5, -5 ???
Thanks
Talal H.
Lex-Imports.com
Old Feb 23, 2004 | 10:00 PM
ItsStockOfficer's Avatar
where are you getting these numbers?
The point of using gears is to increase cam overlap. That is the amount of time you have both exhaust and intake valves open. The air leaving your cylinder from the exhaust helps to pull air in from the intake....but not flat across the board. At lower RPM your engine will idle a bit worse and make less power. You move your peak torque upwards in the rpm band(and lose some.
But HP is calculated by TqxRPM/5252.....so moving torque upwards increase hp.
Old Feb 24, 2004 | 09:05 AM
stevEVO8's Avatar
How is cam overlap increased?
Advancing or retarding the timing?
Old Feb 25, 2004 | 03:13 PM
evo542's Avatar
advance the intake and retard the exhaust? but it has to be tested by a good tuner to not run into any problems
