How much power is the evo IX turbo cable of?
Old Jul 21, 2013 | 01:04 AM
03EvilEvoWhite's Avatar
I am getting a motor built should be making around hp450+. I am curious on if this turbo will be able to withstand a built motor?
Old Jul 21, 2013 | 01:28 AM
Pal215's Avatar
Well, to give you an idea, i'm making 430hp and 414 tq with E85 on a stock evo ix turbo with no cams and no intake manifold or oversized throttle body. You should be able to break 450hp with a built motor.
In terms of withstanding it, I don't see why not as long as you are not boosting past 30 psi all day.
-pal215
Old Jul 21, 2013 | 03:48 AM
9evolution's Avatar
Is the question will the motor blow up the turbo?
Old Jul 21, 2013 | 04:04 AM
foxbat's Avatar
it's the other way around, you build a motor to make it withstand a certain turbo size/boost level.
@Pal215
What boost are you running? making such hp on a stock turbo?
Old Jul 21, 2013 | 05:14 PM
awdordie's Avatar
Thats easily obtainable on a ix turbo. For reference my car previously made 356 on an 8 turbo with a 9 10.5 hotside on 26 psi. In the next few weeks ill be re tuned and trying to achieve 425hp on the same turbo still on stock injectors, and on 93.
Old Jul 21, 2013 | 09:06 PM
I am getting my motor rebuilt right now with light weight crower crank shaft, kelford 272cams (that were previously in the motor) and crower pistons and rods. Port and polished, more to list but yeah. I have the evo IX turbo, and a few people have said to me, "oh getting all that work done that stock 9 turbo is useless" "might as well put a bigger turbo on it". Obviously a bigger turbo would be sick.
My question is the 9 turbo (@27psi) will be just as effective with the new motor as it was with the old? Old motor only had the cams. Will i lose horsepower pretty drastically after a certain rpm (lets say 6500rpm) being that its not a big turbo?
Old Jul 21, 2013 | 09:16 PM
joseph143's Avatar
Yes... Boost taper will be a huge issue on a well builthigher reving motor. Is it useless to use a small turbo? Not at all... I have a motor easily capable of 700-800hp and an ef4 bolted up... But if i go autox i plan to swap it out for a small turbo to get my bottom end back. With a big turbo you'll make crazy sick dyno numbers and possibly be a drag king/queen... But outside of a straightline your *** is mine...
Ps... Evilevowhite.., pm me... I'm down in elp... I hit up ruidoso every othermonth or so...
Old Jul 23, 2013 | 10:53 AM
GSR9's Avatar
-pal215
How many pounds are you running? I'm looking to make sub400awhp too with my stock turbo.
Old Jul 23, 2013 | 11:42 AM
nollij's Avatar
You're going to be blowing nothing but hot air out of the compressor. Let us know how it goes in the New Mexico heat.
My expectations: 415awhp on E85 and 390awhp on 93 oct.
You will be generating so much heat, I don't expect you will be doing much back to back or 1-4 pulls.
Old Jul 23, 2013 | 12:50 PM
SsZERO's Avatar
I think you worded that backwards. Your engine relies on a turbo to make power, so even if your engine can handle a certain amount of boost it's not going to matter if the turbo can't keep up. That said, hitting 350 WHP is a reasonable expectation on the stock IX turbo, using pump gas, and that would be ~24 PSI...you can go higher than 24 PSI but I have not.
To avoid boost taper and hold 24 PSI or whatever you set it, you should use a quality DV. I have been using a synchronic DV from synapse engineering for the last few years and it holds boost rock solid, but I still have about 2 PSI of tapering. I'm still using the stock WG & WG actuator (on a stock turbo the WG is built into the turbo). Replacing this could further reduce tapering.
Old Jul 23, 2013 | 04:30 PM
Blue91lx's Avatar
I run a stock turbo on a 2.4L, and it's the most fun setup I've felt in a while! On the upper end, I'd say you could make around 400whp on 93 (good cams, IM, dump, EM, etc), but the power will be instant, so like jopeph said, unless you're on a straight highway doing pulls all day and night, fun power > big power.
Old Jul 23, 2013 | 04:45 PM
evofool's Avatar
350 is easy, I have an evo 8 with 354hp for the last 40k miles or so on a stock block with only 92 octane with a stock 9 turbo, I have a ported, coated and Fp compressor housing one in a box ready to swap out I just haven't had the time.
Old Sep 2, 2013 | 07:40 PM
Pal215's Avatar
@Pal215
Sorry for late reply,
24psi on 91, 28psi on E85
-pal215
Old Sep 2, 2013 | 09:03 PM
Svendiesel's Avatar
The most boost that was put thru an IX turbo I believe was 38psi. Normally, you dont see many pushing them past 32-33ish. They don't like that.
Old Sep 3, 2013 | 08:42 AM
JohnBradley's Avatar
41-42psi is the max I have seen , they still really dont like much more than 33 or 34 normally.
