Evo 6 radiator into an Evo 9 MR
Old Jul 26, 2013 | 12:10 PM
555R's Avatar
Also an odd tech question. I dropped an Evo 6 radiator into my Evo 9 to replace the cracked plastic end tank. What radiator stays tabs can you use. The Evo 9 stays don't line up at all
I did this because the plastic end tanks either cracked or something. It's leaking so at the recommendation of a friend. I dropped an evo6 radiator and Evo 6 hoses. It dropped right in but the radiator stay tabs don't line up at all. What can be used to lock this thing down.
The 6 radiator places the upper hose away from the manifold.
Any ideas thoughts threats. Yadda yadda
Jonas
Old Jul 26, 2013 | 12:18 PM
2006_RA's Avatar
These guys say it can be made to work, maybe they know how.
https://www.evolutionm.net/forums/ev...half-size.html
This may help more:
https://www.evolutionm.net/forums/ev...r-install.html
Old Jul 26, 2013 | 01:15 PM
MyronGainz's Avatar
This is strange. That's supposed to fit without issue.
What issue are you having with the mounting tabs specifically? Make sure the bottom tabs are lined up and installed with the OEM rubber supports from your old radiator.
If you post a pic of how it sits in the car that might help.
Old Jul 29, 2013 | 06:48 PM
555R's Avatar
The radiator tabs are about one inch farther out than the rubber grommet holes. I put the oem ones on but they don't line up so its more like its just pressure fit in there. Guess ill just make some out of some metal and bend and drill. I just thought maybe I can get Evo 6 radiator stays and see if it works. It's a no name aluminum radiator I needed one stat so couldn't wait and hell it was way less anyway.
DSSA
Evo X How Tos / Installations
19
Sep 7, 2017 02:57 AM
JBAutosports
EvoX 'For Sale' External Engine / Power
97
Nov 18, 2012 05:04 PM
JBAutosports
101
Nov 18, 2012 05:03 PM
Vivid Racing
25
Apr 23, 2012 09:46 AM
I4UnderPressure
Nov 6, 2011 07:16 AM
