Clutch going..
Old Sep 26, 2013 | 04:54 PM
hiboost2.0's Avatar
Originally Posted by evo unknown
Contact them and see what their recommendation is for a clutch. You should be fine with a single plate clutch such as a Competition Clutch Stage 2. They are pretty affordable and an option a lot of people are using now.
+1 I had that clutch it was awesome. The clutch plus install will be around $1k, if you get an aftermarket flywheel it will come out to around $1.3k
The labor rate in New Jersey for a clutch install is $500 - $550
Old Sep 27, 2013 | 02:53 PM
Skinchin13's Avatar
Originally Posted by jhoganusaf
how did the install go? Problems solved? have any pics of the old clutch? sorry to ask so many questions on an older post, but my car was having the same issue before i put it into storage.
The install went good car has no problems. Sorry no pics but the clutch was starting to eat into the flywheel but no problem after the break in period. The clutch holds good
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
AngryEvo8
106
Nov 20, 2014 02:56 PM
High_PSI
141
Jun 15, 2014 05:10 PM
mberenis
May 17, 2014 05:51 PM
mrm95
15
Dec 12, 2013 07:59 PM
