Avoiding heating oil pan with new DP
Old Feb 23, 2004 | 07:41 PM
Capt_Crunch's Avatar
Guys, I wrapped my new HKS DP with some header wrap to avoid heating up the oil pan. Thoughts?
Old Feb 23, 2004 | 07:44 PM
MYEVOVIII's Avatar
I did the same thing. Also it will help the thermal dynamics of the exhaust flow
Old Feb 23, 2004 | 08:11 PM
Quickshift's Avatar
I havent done this to mine. I got a oil temp gauge coming off the oil filter area and I have not experenced any overheating issues. But I can understand how this will help. I may have to look into this. may I ask where You purchased the wrap?
Old Feb 23, 2004 | 08:12 PM
SOF's Avatar
SOF
header wrap voids the warranty
Old Feb 23, 2004 | 08:25 PM
Local performance shop here in AZ. Lopers Performance. I used ThermalTec, kinda pricey, but good stuff.
Old Feb 23, 2004 | 08:27 PM
On an aftermarket DP? huh? Kinda moot point. heh
Old Feb 23, 2004 | 08:32 PM
SOF's Avatar
SOF
Your HKS DP didn't come with a warranty?
Old Feb 23, 2004 | 08:44 PM
Creamo3's Avatar
The HKS pipe does not appear to be too close to the oilpan compared to 3" pipes, but I guess it won't hurt any and may speed up exhaust gases by keeping the heat in the pipe.
Old Feb 23, 2004 | 10:57 PM
value's Avatar
The HKS Kansai downpipe comes with heat wrap.
Old Feb 23, 2004 | 11:09 PM
hagakure's Avatar
Easy answer: WORKS DP. thermal coated.
Percy
Old Feb 23, 2004 | 11:20 PM
Conduit's Avatar
Have it coated by SwainTech.
That wrap turns into a mess when it gets wet.
If you get it coated, don't put it back on, or you risk overinsulation.
Old Feb 24, 2004 | 03:25 AM
EVOVII_SWE's Avatar
My Fujitsubo DP is about 2,75" and it came with an adhesive heat shield to put on the oil pan.
Old Feb 24, 2004 | 03:50 AM
RichJ's Avatar
IMO the wrap isn't worth the money. It cost around $40-50 once you get the wrap, the clips, the high temp sealant paint, etc. For just $25 more you can get a high quality coating. And while there are mixed opinions, the wrap is considered a fire hazard by some:
https://www.evolutionm.net/forums/sh...threadid=55438
Old Feb 24, 2004 | 05:47 AM
chuntington101's Avatar
Good idea mate. No point in an oil cooler if you are just going to let the exhaust heat it up. While you had the wrap though, you could have done the exhaust manifold, or maybe got a manifold and turbo kit, these will help reduce the under bonnet temps no end! To the guy that thinks the wrap is dangerous, how come virtually every racer uses the stuff?
Old Feb 24, 2004 | 09:04 AM
Creamo3's Avatar
Probably because they have fire extinguishers in the cockpit and don't drive their cars everyday
