4G64 harmonic /crank balancer info
Old Aug 4, 2013 | 05:10 PM
GAT007's Avatar
Hi all i im in the process of building my 4g64 / evo 7 head , the block i sourced did not have a crank pulley so i have looked around to see what was available O.E.M and aftermarket but i cant seem to find an aftermarket one for the 4g64 7 bolt ? ATI , fluidamnper etc... only for 4g63
I will be running 100mm crank Manley TT , magnus 156mm rods , Mahle stroker pistons and will run 100 octane fuel with aquamist HFS3 , Map EF3 and stock manifold ...
It will be a weekend warrior with the occasional track / drag meet .
Also i know its probably been mentioned or i should have researched it but the EVO 7 gearbox is strong but at what level or HP rating should i consider upgrading it ? and Transfer case has issues but would 500WHp cause problems or should i upgrade ?
im in Australia , Melb and we dont have a great deal of places or people to talk to so any advice is welcome thanks
Old Aug 5, 2013 | 07:51 AM
ChrisCarey's Avatar
The standard Evo 4g63 crank dampers will work for you sir
Blitz
Oct 24, 2013 07:44 AM
sktng22
23
Dec 25, 2011 11:20 AM
BLKCarbonEVO
31
Aug 23, 2011 11:39 PM
ecuflasher
44
Apr 8, 2011 05:50 PM
nianlala
30
Feb 5, 2007 10:14 AM
