View Poll Results: CEL with HKS 272s?
Yes
11.54%
No
19
73.08%
Depended on other mods
15.38%
Voters: 26. You may not vote on this poll
HKS 272 cams CEL!!!
Old Feb 25, 2004 | 07:31 AM
FreddyP's Avatar
i have the 272 combo installed and am definitely getting CEL's. i am getting misfire in cylinder 1 mainly. i also have another friend with the 264/272 combo getting the same CEL's as me. i generally get the CEL after idling for a long time. fwiw, me and my friend go to different tuners. i am using the e-manage, and he is using the s-afc.
Old Feb 25, 2004 | 08:05 AM
4G63>OOOO's Avatar
Try enriching the mixture between 800-900rpm's.
Old Feb 25, 2004 | 08:16 AM
jbrennen's Avatar
I've had a few CELs since putting in the HKS 264/272 combo.
Most of them I attributed to boost cut, unrelated to the cams -- those apparently cleared up when I got reflashed to raise the boost cut threshold.
The only one I've gotten since the reflash (over about a one month period) was the P0300 random misfire, which happened once, two days ago.
Old Feb 25, 2004 | 04:48 PM
Toddevo 8's Avatar
A friend of my has the 264-272 cams I have the 272- 272 cams. If you Ajd the Idle down this will help will help with the cel. Idle at around 800 or less.
Old Feb 25, 2004 | 07:59 PM
propellerhead's Avatar
I don't have the 272/272 but I do have the 264/264 with a BR 3" turbo back. I generated a CEL this past weekend. I was low on gas so I filled up my tank and afterwards I made sure I tightened the gas cap until it clicked. The CEL went away. I haven't pulled the code yet to verify that it was the gas cap.
Just something to consider.
Old Feb 25, 2004 | 08:51 PM
Turboholic's Avatar
i donot think so.
at lease mine doesn't.
Old Feb 26, 2004 | 06:22 AM
smackdaddy's Avatar
I agree with 4G63>OOOO, richening up the bottom end of the fuel curve seems to help.
Also I found that with the stock BOV and an AEM intake it seems to cause some idle/stalling problems I'm guessing due to low vacuum. That may also be a problem source for a CEL since the engine did seem to stumble alot like that. Once I put my FORGE DV back in idle is rock solid at 800-900 rpm.
I can anyone else confirm if they have a problem with the stock BOV and 272/272 cams?
Old Feb 26, 2004 | 07:58 AM
BadBoyBeltran's Avatar
I got a CEL with the 272s installed yesterday. I'm about to get the CEL read.
Old Feb 26, 2004 | 04:04 PM
Turboholic's Avatar
i have no problem with hks 272/272 using stock bov and speed-source intake.
my mistake, i should not tell about the CEL for the cams, because i took off the stock ECM already. i totally forgot about that.
Old May 7, 2005 | 04:30 PM
LancerEVOmann's Avatar
Does your car start rumbling and shaking and experiencing a loss in acceleration when the p0300 is fired? Mine does in 5th gear at about 3000 rpms. I was just wondering because I want cams but I don't want the p0300 all the time!
Old May 7, 2005 | 06:51 PM
Zeus's Avatar
OK, here is an experienced opinion... for those having idle, stumbling, stalling issues with your 272's... put your OE MAF pipe back on. 272's on OE cam gears with an OE flash, idle ok with the OE MAF pipe... and idle really damn well with a little tuning on the OE MAF pipe. Without going into detail, the OE "corrugated" MAF pipe helps keep intake reversion from affecting the MAF signal where a nice flowing aftermarket smooth one doesn't... which can cause many of the problems in your complaints. Of course the aftermarket pipes "make power", and can be "tuned around", but don't take my word for it... try it!
CeeWhizzle
Feb 28, 2013 09:43 AM
Slo_crx1
Jul 20, 2008 05:46 PM
taylor
May 7, 2005 04:18 PM
Trustz
Jul 9, 2003 05:06 PM
