Cams acd CELS?
Old Apr 20, 2005 | 07:17 PM
taylor's Avatar
Cams and CELS?
I have a few questions in regard to cam issues.
First, how common is it to get a CEL after a cam install(I'n planning on getting the 272/264 combo)? How hard is it to tune the CEL out through ecu reflash? And, what exactly causes the CEL in the first place? I've read it is often caused by an excessively lean condition, are there any other factors?
I'm curious because I live in a state which test emissions via OBD scan , and I would rather not have to change out the cams every year.
Thanks for the help!
Old Apr 20, 2005 | 07:21 PM
PVD04's Avatar
I have HKS 264/264 without any CEL problems. I haven't heard of anyone getting a CEL due to cams if they were flashed for them. The only exception is the P0300 code, but that affects people with stock cams as well.
-Paul
Old Apr 20, 2005 | 08:25 PM
taylor's Avatar
Thanks. I've read of a few people getting CELs w/272's. Maybe it is just lack of tuning.
The 264/264 setup would probably be least likley to cause a problem, right?
Old Apr 20, 2005 | 08:32 PM
nickracer9's Avatar
my untuned 264/272 combo hasn't thrown any cel's.
Old Apr 20, 2005 | 09:04 PM
Nad1370's Avatar
Straight 264's here and no CEL's 20K+ miles.
Why are you considering 272/264 ?
Old Apr 21, 2005 | 12:16 AM
GREDDY's Avatar
If you get a CEL after cam install then the cams weren't installed right.
Old Apr 21, 2005 | 06:23 AM
spyderx's Avatar
I got a cel after my 272/272 installed and tuned w/o cam gears.
But then again it went away after a day by itself.
I was told it's not a concern for those w/ ecu flash. Just more of annoyance.
Probably lumpiness of 272 is the general source of the cel.
Old Apr 21, 2005 | 06:39 AM
umiami80's Avatar
Most people who GET Cels with cams liek 272 is because you have a RICH ldle.
Old May 7, 2005 | 04:18 PM
LancerEVOmann's Avatar
I have the problem ever since I got my Exedy Hyper Single clutch installed. I know the P0300 can be thrown from a overly sensitive knock sensor. Some Evos have them, some don't. Unfortunately mine is sensitive. Another reason can be a change in harmonics, which I think is what happened to mine.
Mitsu has a flash for the P0300, but if u have a aftermarket flash already it will erase it. Plus I heard it doesn't really work that good anyways. Hope this helps.
mitsuorder
226
Jun 4, 2022 10:30 AM
CeeWhizzle
Feb 28, 2013 09:43 AM
211Ratsbud
21
Nov 4, 2012 07:07 PM
XxLaNcErGTSxX
Jul 9, 2008 07:46 PM
crow
Jun 26, 2005 11:56 AM
