Just finished compression testing on my Evo 8 with 103k miles.
Old Aug 23, 2013 | 03:57 PM
Randal's Avatar
Guest
I have an Evo 8 with 103k miles, dont know if the motor was built or not previously. So I did a compression test how I read in the forums and this is what I got.
1st 165psi
2nd 165psi
3rd 165psi
4th 160 psi
Wet as in added a couple of drops of oil in cylinder before testing.
1st 170psi
2nd 165psi
3rd 165psi
4th 165psi
I read the evo 8 by factory is at 163psi? What the hell?
Old Aug 23, 2013 | 08:51 PM
94AWDcoupe's Avatar
great compression. ready for bigger turbo. like a 3076 on e85.....
Old Aug 23, 2013 | 09:27 PM
rjfg's Avatar
Nice all across the board
Old Aug 24, 2013 | 05:01 AM
Randal's Avatar
Guest
Does this mean maybe the motor was recently rebuild? Because at my mileage it's impossiblemtomhave more compression then when the car left the factory.
Old Aug 24, 2013 | 05:24 AM
EvocentriK's Avatar
All compression testers read differently. You use them to give you an indication of ring/cylinder health and differences between cylinders rather than looking really hard at absolute numbers.
Mine has 50,000 kms and I ran 160/160/160/160 a couple months ago when I did mine.
Old Aug 24, 2013 | 06:53 AM
aggieEVO's Avatar
My tester read 185 for each cyl. It just depends on the tester. The thing to be happy about is the consistency. You don't have a bad cylinder.
Old Aug 24, 2013 | 08:04 AM
barneyb's Avatar
Compression can increase over time due to burnt fuel and oil deposits in the cylinders. In car engineer's lingo this is known as octane creep.
Old Aug 24, 2013 | 08:53 AM
Randal's Avatar
Guest
Even in E85? It's practically a fuel additive cleaning everything it touches lol
Old Aug 24, 2013 | 09:28 AM
cmspaz's Avatar
WAT.
E is a terrible solvent, but it doesn't produce the soot pump gas does, that's why your motor stays clean.
Old Aug 24, 2013 | 10:26 AM
SDevo13's Avatar
It would be easy enough to pull your oil pan. Aftermarket rods (which everyone does with a build since the stock ones are the weakest link) would be very easy to spot. You won't be able to tell if its built just from compression tests unfortunately.
Old Aug 24, 2013 | 03:50 PM
barneyb's Avatar
Years ago the standard multi-weight oil used in gasoline engines was 10W-40. The reason for the switch to 5 or 10W-30 wasn't just for gas mileage it was also because 10W-40 oil tended to cause a lot of deposits. Cars, as they accumulated some miles, would start to knock.
Old Aug 24, 2013 | 05:36 PM
High_PSI's Avatar
Who still runs a single scroll 3076 this days with the just as powerful if not more so and faster spooling FP & BBK turbos?
That is a very consistent readout, very good numbers and a healthy motor.
ctfpevoVIII
Jul 12, 2015 07:07 AM
RalliMark
For Sale - Cars For Sale
26
Dec 8, 2014 08:08 PM
RedEvoxGSR
20
Dec 18, 2013 02:12 AM
Randal
Oct 6, 2013 09:44 AM
vinnieg
18
May 8, 2012 01:48 PM
