What's the best intake?
Old Feb 24, 2004 | 08:27 PM
Mattsteg45's Avatar
What's the best intake horsepower wise for my evo? I've looked at the AEM, Injen, K&N, HKS, and ARC. Any advice?
Old Feb 24, 2004 | 08:33 PM
fury656's Avatar
On the stock turbo from the results I've seen luckily a K&N Panel filter seems to be as effective as any in tuned applications in picking up a few extra hp. As for the other conical style filter setups theyre mostly noise. Also I would not modify anything on the intake side untuned, our ECU's dont seem to compensate correctly causing overly lean condition in some instances as with conical style filter setups which is never a good thing.
Old Feb 24, 2004 | 08:49 PM
Mattsteg45's Avatar
Ok, thanks, I just ordered a UTEC, so that should help that
Old Feb 24, 2004 | 09:01 PM
boostedwrx's Avatar
The stock filter is the best for the stock turbo.
Old Feb 24, 2004 | 09:03 PM
Az3ar's Avatar
stay stock for now, or change to K&N stock filter
Old Feb 25, 2004 | 11:53 AM
Z1 Performance's Avatar
do some searches...there are probably 100 threads talking about this
Old Feb 25, 2004 | 12:02 PM
mjones53's Avatar
Yes, just use the K&N drop in, I had the HKS RS, didn't do anything for me but make a lot of noise. Went back to stock.
Old Feb 25, 2004 | 12:08 PM
simevo's Avatar
Wait till Works come out with their intake kit. I've heard that it would be like stock set up but just better. Other wise, stock box with high flow filter is way to go.
Old Feb 25, 2004 | 02:15 PM
Creamo3's Avatar
search and you will see
