Driving in 5th gear in low RPM & driving with ac on?
Old Aug 27, 2013 | 03:40 PM
OriginalPham's Avatar
I have two questions. I am new to Evos and recently picked up a 03' Evo. I changed all the fluids for the motor, tranny, tc, and diff on time. But some things I noticed, if I drive in 5th under 3 RPM, the car rumbles while driving. But once I am over 3 RPM, car drives normally. My other problem is when I use the ac, the car feels weak. The turbo goes off, but the car doesn't gain any speed? Can someone help?
Old Aug 27, 2013 | 07:47 PM
barneyb's Avatar
The 2003 Evo VIII's and maybe other years have an NVH problem in 5th gear at the rpm you mention. People say it is the transmission, transfer, clutch or other parts. I notice what tire I am running makes a difference. I dunno the real answer or fix.
The Evo 4 cylinder is tiny with little torque until boost comes on. The AC soaks up about 25 hp. Add in hot weather meaning thin air and the car is doggy on a hot day.
Old Aug 28, 2013 | 07:26 AM
Nimpoc's Avatar
My '04 doesn't get too shaky 'till down around 1500. There's no real power down there but if you're just putting around town it's fine.
Has anyone improved this with tuning? It seems like this could be improved with timing map changes thru reduced timing and therefore softer torque pulses...
Purps
Jul 15, 2014 04:52 AM
PSM3
Mar 2, 2014 11:34 AM
blade3609
44
Nov 6, 2011 12:44 PM
jameswwt
10
Sep 18, 2011 12:53 PM
AlwaysinBoost
Jan 4, 2006 04:09 PM
