Id1300 injector scalings
Old Aug 28, 2013 | 04:40 PM
evoyrrah's Avatar
Has anyone messed with these injectors yet? I got some heading my way and it would be good to have a good starting point
Old Aug 28, 2013 | 04:46 PM
EvocentriK's Avatar
ID's come with a sheet stating latencies yeah? My ID1000's did and they're available on their site too. Scaling is going to differ a bit car to car, try 70-80% of the injectors rated size and go from there using trims.
Here:
Dynamic Flow Rate and Dead Time Summary section has the latencies
http://www.injectordynamics.com/ID13...Specifications
Old Aug 28, 2013 | 06:27 PM
JohnBradley's Avatar
Not really the forum for it but I'll answer anyway.
On gas if they are a true 1300cc I'd start with 1125 up to 1170 with the latency they provide. If its on the positive side of the trims (i.e. +15% vs -15% for negative) I would drop that number till its about -3% or so. Then drive it and you should see cruise trims somewhere around zero in steady state. Thats normally an indication its close.
MAF or SD?
Old Aug 28, 2013 | 06:57 PM
evoyrrah's Avatar
It's on maf John
Old Aug 29, 2013 | 08:47 AM
evoIXcencal83's Avatar
I just ordered the same ones.
Old Aug 29, 2013 | 09:29 AM
I've been told they werent 1300cc on calibration fluid so these may be smaller in reality.
Old May 29, 2014 | 11:20 PM
mrfred's Avatar
anyone have these dialed in on an 8/9? would be curious to see the values, esp for e85.
Old May 30, 2014 | 05:34 AM
evoyrrah's Avatar
On my walbro 416 I was dialed to about 730.... Now with my my double pumper setup I haven't finished tuning I'm at 800 on e85 so far
Old May 30, 2014 | 08:56 AM
I have had them on a Subaru on gas. They scaled like the Fuel Injector Clinic 1100.
mrfred's Avatar
800 cc/min would be about right for a 1300 cc/min injector. How is the drivability?
Old May 30, 2014 | 08:59 AM
mrfred's Avatar
Wow. That would be way undersized for the implied flow rate because FIC1100s scale like an 1100 cc/min injector.
Old May 30, 2014 | 09:02 AM
Perhaps it was the software but I started with an 1100 map on said Subaru that was dialed and had been used on a similar setup for 590whp. The car started up and was on the trims. The scaling and latency was close enough I fine tuned the rest of the idle and cruise in the MAF tables and then went to the WOT stuff later.
foxbat
Apr 21, 2017 12:50 PM
Aproductions
Jan 31, 2017 08:17 AM
nikush
Apr 13, 2016 01:47 AM
napsu67
Oct 20, 2015 09:45 PM
oscarquinones
Aug 26, 2013 07:29 AM
