Speed density on stock 9 turbo?
Old Sep 3, 2013 | 06:42 PM
ChicagoEvo9's Avatar
I've done some research and what I've come up with is speed density is only beneficial when going with a bigger turbo than stock because at that point MAF becomes a restriction..
Would like some insight on this as I am not too familiar with SD at this point
If speed density would be beneficial to me, I will definitely throw it on my setup so all opinions are appreciated!
Thanks
Old Sep 3, 2013 | 08:31 PM
alleggerita's Avatar
I have a much milder set-up and I am sold on SD. Absolutely love the car. Power up slightly, drivability once warm way better.
Also see this link:
https://www.evolutionm.net/forums/ev...ock-turbo.html
Old Sep 3, 2013 | 09:38 PM
Also see this link:
It's a good read thanks! I guess if I'm not having any issues with my maf then idk if I should switch over.. Other than the 10 hp gain
Old Sep 3, 2013 | 09:47 PM
The big thing for me was part throttle drivability - that is really THE reason to do it. It makes the car much more enjoyable and easier to place and drive quickly on back roads.
Old Sep 4, 2013 | 06:53 AM
Stock turbo?
Old Sep 4, 2013 | 08:00 AM
bone stock
Old Sep 4, 2013 | 08:05 AM
chu's Avatar
chu
This. The biggest advantage is partial throttle driveability. It's a noticeable difference, especially since I track my car. No more bucking under partial throttle.
Old Sep 4, 2013 | 08:16 AM
joseph143's Avatar
According to some thners the stock maf is good to 700+... I switched sd because of part throttle bucking... When getting tuned by a GOOD tuner you dont even need the iat sensor... Which makes it 100 plus tune for a better driving car. Plus if youhappen to blow off you piping you can still drive to a decent place to fix your car rather then getting stuck in traffic or the highway... Both of which have happen to me. After sd i blew off a pipe and drove for 30 miles to the house with no issues so i could fix my car in peace.
Old Sep 4, 2013 | 08:23 AM
My tuner recommends MAF ):
Old Sep 4, 2013 | 09:17 AM
PureDrivePerformance's Avatar
In that case I think you should do a MAF tune. Some tuners aren't comfortable doing it yet or feel it's not a big enough gain to switch. Like Aaron at ER said on a stock turbo it's 10 HP at best.
What kind of racing do you do?
Old Sep 4, 2013 | 01:59 PM
romogst's Avatar
Just get the SD, you are modifying your car anyways, i'm sure down the road you'll have a bigger turbo.
Old Sep 4, 2013 | 05:55 PM
Street
Old Sep 5, 2013 | 09:03 AM
JohnBradley's Avatar
8-10whp is average. But if you are looking for that last 8-10whp its worth doing of course. As was said earlier though, if your tuner isnt comfortable doing it then its decision time. Either get a new tuner which is extreme or heed his advice and then just tune the car on a MAF.
Aaron
romogst
May 11, 2018 05:15 PM
03whitegsr
Oct 8, 2017 08:16 AM
TheLancerLife
Mar 18, 2017 02:13 PM
aquaplane
Jul 19, 2016 11:39 AM
Jsocpro20
Feb 7, 2010 09:28 AM
