Difference between grimspeed ebc vs ebcs?!
Old Sep 10, 2013 | 07:43 AM
ChicagoEvo9's Avatar
Was looking to purchase a grimspeed 3 port ebcs and then I saw others offer just a ebc.
Not sure what the difference between ebcs and ebc is? Are they both the same?
Help!
Old Sep 10, 2013 | 07:50 AM
vortico's Avatar
An ebcs is electronc boost control solenoid, an ebc is an electronic boost controller. The grimspeed is an ebcs which uses your factory ECU and factory connectors to control boost (after a flash to tephra v7 and a tune). An ebc is a standalone unit in most cases that will let you modify boost from inside the cabin. An ebc is similar to a manual boost controller in the way that the car's ECU does not control the boost curve, it does. (For instance an AEM TruBoost). You also need to tune the car in this case but the ECU is not controlling boost.
Two very different boost control methods.
legacyGSR
Nov 6, 2015 11:54 PM
Jake.barratt
Jul 2, 2013 04:48 PM
Lancerally_Mick
Aug 5, 2011 06:57 AM
volcano
Dec 24, 2010 03:45 PM
