Injector signal issue
Old Sep 15, 2013 | 07:34 PM
xRoguex's Avatar
Ok -- I have now been fighting this issue for over a year. Its intermittent. And it keeps me thinking I've fixed it - but then it comes back.
# 3 injector just -- DUMPS fuel.. goes WOT and my AFR drop to --- well it dumps fuel out the exhaust.
I have replaced/checked
Injectors(swapped them around does not follow injector, tried different injecors as well)
resistor pack
wiring harness
Cam angle sensor(New OEM)
Trigger plate
Crank angle sensor(New oem)
COP(Moved coils around - does not change)
The only thing I can think of -- is the ecu board is bad with respect to the injectors.
It does NOT throw a code ...
Im open to ANY ideas... ugh
Old Sep 16, 2013 | 05:19 PM
xRoguex's Avatar
Anyone ever had an ECU go bad?
Old Sep 18, 2013 | 04:55 PM
xRoguex's Avatar
No one?
Old Sep 19, 2013 | 07:03 AM
J_Striker's Avatar
You could have any intermittent short to ground on the #3 injector wiring. Next time it happens, test the ground side of circuit for continuity to ground with the engine off. If you have continuity, unplug ecu and test again. If you still have a ground, then there is a short to ground. If not, the ecu is messed up.
Old Sep 19, 2013 | 07:37 AM
Evoryder's Avatar
i had a ecu go bad due to a flashing issue.
This condition only happens when you go WOT?
Old Sep 22, 2013 | 05:31 PM
xRoguex's Avatar
condition happens randomly... driving.. wot... idling.. etc.
pennies_hatchie
68
Mar 5, 2023 08:02 AM
ReivaXVrai2
15
Nov 28, 2015 11:42 AM
EVOlutionary
Jul 18, 2013 08:53 PM
Slickonice
11
Jan 13, 2013 09:06 AM
