stock ecu
Old Feb 25, 2004 | 06:47 PM
EVOMIZ's Avatar
stock ecu
how much is a stock ecu? i think i might have killed mine
Today I installed a o2 housing with an extenal dump tube, after installing i left a bunch of crap on the passenger floor near the ecu. While test driving i notice the afc was blank i was like WTF, so i pulled over and notice all the crap pushed up to the ecu and the afc wiring, so i cleared the floor and the afc came back on. so as i am driving back i get on it and as the wastegate opens (LOUD AS ****) up the car shuts off after about a hour of tring to see what wrong I find a blowen fuse for the ecu, I changed it and the car starts. So i start driving and as soon as i get on it and the wastegate opens the fuse blows again (five times). Now i have taken the afc out of the car and trace all my eletronic in the car for a short and i found nothing.
any ideas
maybe ecu
i don't think it could be the external dump and i wrong I don't really want to take it of and it is not the problem, it was a ***** to get on. car ran fine up untill today
Old Feb 25, 2004 | 07:01 PM
992gnt's Avatar
where does external wg dump to? Any wiring or sensors nearby that you could be overheating?
Old Feb 25, 2004 | 07:06 PM
EVOMIZ's Avatar
it replaces the stock o2 housing no know wires or sensors it close to the ac compressor
Old Feb 25, 2004 | 09:14 PM
dirty_barry's Avatar
Normally I would say you are too close to wires with the dump (the same things with some DSMs and alternators), but it appears you have a different problem. Clean up all the jumble you said you had down there and check for crossed wires and possibly test the wire that runs to the fuse for the ecu.
-Brady
Old Feb 25, 2004 | 09:55 PM
evo542's Avatar
Re: stock ecu
if your ecu is burned up, you might as well go with standalone, but you have to know what caused this mess to occur in the first place
Old Feb 25, 2004 | 09:57 PM
BadBoyBeltran's Avatar
Utec - $999.99
Old Feb 25, 2004 | 10:05 PM
fimotorsports's Avatar
Originally posted by BadBoyBeltran
Utec - $999.99
utec isn't actually a standalone, it plugs into your existing ecu... it's really a piggyback.. Standalone is more like the AEM
Old Feb 26, 2004 | 06:54 AM
Dale_K's Avatar
I think a new stock ECU is about $900. I checked one time when I was thinking of reflashing and having 2 ECU's, one stock, one flashed. You want to be sure you really need it so I'd advise you to put everything back to stock just to be sure it's not your wiring mods.
Old Feb 26, 2004 | 07:12 AM
EVOMIZ's Avatar
Thanks I am planning of taking the day off tomorrow and take all my eletronics out. Is there anyway to check the ecu?
Old Feb 26, 2004 | 05:03 PM
Grod101's Avatar
each ecu for the evo is specific for that car.. you can't change them out to another persons car... just get the AEM
BosanskaTrava
20
Apr 1, 2008 09:19 AM
o4whtevors
46
Nov 9, 2005 08:37 PM
ebbeast2005
46
Dec 17, 2004 02:42 PM
Fourdoor
14
Feb 3, 2004 06:34 PM
the evo wins
Jun 3, 2003 09:25 AM
