Best turbo for 3k RPM full boost spool??
That was a MIVEC 2.4 with the 7460. Torque was pretty ridiculous and really it needed to be on E85 to be the most fun. You can run it on gas of course but making that much torque that fast it would be better on high octane.
Here is the dyno sheet -
Rest of the thread here - https://www.evolutionm.net/forums/ev...4-hks7460.html
On a stroker motor with say a 2.3 or a 2.4 with a stock 9 turbo, does the potential for compressor surge increase or become a problem? Also, does the fairly "small" airflow capacity of a stock 9 turbo become too limited given the considerable increase in the volumetric efficiency of a stoker?
More or less tapped out as far as power on a 2.4 with 10:1 compression and a stock IX turbo. We could have made more torque but it already had traction problems on the street.
7163 will be out soon enough and can move 60 lbs/min.
Here is one making a little more power, it also has an overlay of one of the first pulls with a 34mm restrictor on it...ignore those
I make them work where the right housings are available.
The IX turbo with a big motor and a lot of boost down low will surge.
Gotcha! Different beast! ( probably more efficient + + airflow)
I have the hta 71 and I see 20 psi by 35-3600 normally and the slope is only increasing from there.
How does the hta71 compare to the closest efr counterpart?
I've updated my dyno thread https://www.evolutionm.net/forums/ev...gear-pull.html you can see how do "Hampsters" work work for me. ))
Treyzian
11
Sep 19, 2022 07:15 AM
