Spec Clutch SERIOUS ISSUES
Old Sep 23, 2013 | 09:13 PM
TwinZEvo's Avatar
Spec Clutch SERIOUS ISSUES *UPDATED WITH PICS*
Well, after $1100 later, two weeks of waiting on parts, 3 days after my car was fixed I'm right back where I started with ANOTHER broken clutch.
I was driving my car about two weeks ago. I shifted from first to second and the clutch pedal stuck to the floor. I pulled it back up and it was like pushing against a brick. It was stuck. Took it to the shop and come to find out, the snap ring that holds the throw out beating in place broke in half. (KEEP IN MIND THIS CLUTCH HAS LESS THAN 800 MILES ON IT). I called spec and they said I'd need to order a new flywheel because the ring is "built into the flywheel itself". $400 and a week later I finally get the flywheel. Shop installed everything including the TOB spec provided.
3 days later I'm driving the car and the exact same thing happened again! What I want to know, is Specs products really that bad or what's the deal here? I've got the stage 2 kit. I'm making around 400 awhp and 375 awtq. I'm very disappointed with the kit so far, obviously. I think Spec should be responsible for replacing the broken parts and paying for labor. What do y'all think?
Old Sep 23, 2013 | 09:29 PM
sktng22's Avatar
spec clutch is complete garbage i dont know how there still in business. theres threads all over this site about how bad they are
https://www.evolutionm.net/forums/ev...-clutches.html
Old Sep 24, 2013 | 09:37 AM
TwinZEvo's Avatar
All I can say is I'm very unhappy with their parts and they need to replace what they messed up. Two times in less than a week of driving is pretty bad.
Old Sep 24, 2013 | 10:27 AM
thepoint4life23's Avatar
Was it a Spec clutch that blew threw a guys trans and floor board in his car about 4 years ago ?
Old Sep 24, 2013 | 02:59 PM
batty200's Avatar
The ring is built into the pressure plate. The fix to the snap ring problem is called ACT MonoLoc. It can't break like a stock one can. I also don't believe you needed a new one to start with. The MonoLoc replaces the clip in any stock style clutch. It could have been installed incorrectly by the shop. It is tough sometimes to line up the input shaft to the clutch without hitting and possibly damaging the stock clip. The MonoLoc is much more durable to that damage as well.
Old Sep 24, 2013 | 09:59 PM
TwinZEvo's Avatar
I also thought the same thing but Spec said they "build each part to order", and that the only way for me to get the snap ring would be to get a new flywheel. Which is bs because if they build each part to order, why couldn't they just send me a new snap ring. Also the TOB popped into place too easily is what my mechanic said. It should have a tighter fit.
I honestly just think Spec screwed me over. I just want my money back for the broken parts so I can go ahead and order a new kit. I'll never deal with Spec again after this.
Old Sep 24, 2013 | 11:44 PM
sktng22's Avatar
good luck getting anything out of them. I think they only people that deal with them alot now is the volkswagen crew but thats not saying much
Old Sep 25, 2013 | 08:13 AM
batty200's Avatar
They are not going to give you a thing. I would just either order a MonoLoc and move on or Gervais new kit but waiting on special is a losing proposal. They think you messed it up which is easy to-do so they won't do a thing.
Old Sep 25, 2013 | 07:08 PM
TwinZEvo's Avatar
What exactly does the MonoLoc and Gervias kit do? I've never really heard of those.
Old Sep 25, 2013 | 07:28 PM
batty200's Avatar
I don't know what Gervais is my phone auto correct that. I meant order a new kit. MonoLoc is a clip that can't pop out and get broken from install. I have one on my act HDSS and will put it on any clutch in any EVO forever.
Old Sep 25, 2013 | 07:30 PM
5LEEPERISAH23I's Avatar
Act isn't bad if you don't mind lock out. Other wise just fork up the money and get a twin disc exedy problem solved
Old Sep 25, 2013 | 08:07 PM
xRoguex's Avatar
spec is still in business?
Old Sep 25, 2013 | 08:18 PM
sktng22's Avatar
just went on spec website and all i have to say is wow. they have the nerve to sell a twin disc for 1500+. haha what a joke exedy is 10 thousand times better and the same price
Old Sep 28, 2013 | 10:02 PM
TwinZEvo's Avatar
I would definitely do that, BUT I called spec and apparently they build the snap ring into the flywheel. So I don't know how I could get the monolock deal to work. This sucks. I'm just tired of their BS. If I could offer anyone advice, do not buy anything Spec related, unless you like their stickers, because that's the only quality part they make.
Old Sep 28, 2013 | 10:03 PM
TwinZEvo's Avatar
I will have pictures for you guys to see hopefully Monday and Tuesday.
