Greddy profec b 2 not controlling the wastegate
Old Oct 10, 2013 | 05:19 PM
Eviiil9's Avatar
So before I built my motor the BC was working fine after the built was done and everything installed the BC is not controlling the waste gate, I have connected everything right and only put out spring pressure psi, I connected a manual boost controller to see if it work and it does fine. Any one might an idea why the EBC is not working? Thanks
Old Oct 10, 2013 | 06:55 PM
mt057's Avatar
What are your settings? How is it hooked up?
Old Oct 10, 2013 | 07:22 PM
Eviiil9's Avatar
We have try every possible way that we have seen online and even on the greddy website on how to hook it up to an external waste gate but still nothing
Old Oct 10, 2013 | 07:23 PM
Eviiil9's Avatar
There is also an article here on evom that I saw and the guys was explaining on how to set it up and still didn't work all I got was spring psi
Old Oct 10, 2013 | 08:09 PM
Eviiil9's Avatar
I guess my next step is trying to get a new solenoid and see if that fix the problem
Old Oct 11, 2013 | 09:35 AM
mt057's Avatar
Its difficult to help someone who wont provide information on the current situation.
I have no idea what you have read on the internet or how the current configuration is and much less the settings. Kinda makes it hard to push you in the right direction.
Good luck with swapping things out. Hope it fixes the problem.
llDemonll
Sep 22, 2021 05:43 PM
Weathergeek
Sep 8, 2016 12:41 PM
brunz4g63
Jun 10, 2014 05:42 PM
DEL TURBO
Apr 24, 2010 10:10 PM
