Horsepower on pump.
500+ on a dynojet with supporting mods should be no issue with a 6266 with a good turbo kit and good parts combination that works well together. and of course the fuel needs to be good!
I made 534whp on pump 93 with a 6262 @ 28psi on a stock block. I would imagine with a built motor and a good tune you could see 550-600whp. I don't know how much more boost you could run on pump, before you would need a higher octane fuel.
Ok then. With the mods that having done are a mdr stage 3 2.0l long rod built that's capable of 800, 2150cc, gsc s3 cams, tial mvr 44mm, built s2 tranny from tre transmission, n the 6266 or 6466 turbo.
https://www.evolutionm.net/forums/ev...ali-91oct.html
really, just depends on the tuner imo if it has the right parts to make power... just got done getting my tuned half hour ago tom made it happen!!! running 33psi on cali 91 (0) knock making 523whp. lol keep in mind thats safe as well haha not maxing out on 91 but i wanted it over 500+ he made it happen like it was nothing!!
I did 601whp on 25psi , 22psi 576whp , 14.5psi 459whp all that were done on 91oct .
725whp pump gas 91oct and meth 29-30psi . 881whp C16 on 40psi . ( DJ )
My car is running MAP stage2 2.1L , AMS CNC head , S3 cams , MAP T4 6766 twin scroll kit .
Fameevo: my tuner is really good tuner n he knows what he is doing. Ik that his evo is making like 850-900.
Evo (boss) that's awesome bro. We have 93 oct where I'm at.
Car_nut15: wow that's pretty good.
NY Black momba: That's cool.
so many factors but tscompusa know there stuff. Hit them up if you have any question on a build
I know you are running a 6766, which will produce more power than a 6266 at the same boost level but I highly doubt it would make the same power at 14.5psi as I would make at 26psi.
Can you please post dyno sheets? I live in Dubai and our quality of gasoline is the same as Saudi, or even better with 98Ron. So I don't see how you made 459awhp with only 14.5psi
