ETS short route w Honda battery mod
Old Oct 25, 2013 | 06:35 PM
Coqui's Avatar
Just trying to see if anyone has done the ETS short route upper pipe with a Honda battery swap..seen the battery can be swapped out and prefer that over a mini battery kit..just unsure if recirculation pipe will clear Honda battery
Thanks
Old Oct 28, 2013 | 09:53 AM
Str8Ryda's Avatar
most short route kits won't work with anything outside of a mini battery kit. your probably better off relocating a full size battery to the trunk.
I believe NiseiEngineering.com has a relocation tray and their blowing everything out right now.
good luck
Old Oct 28, 2013 | 11:46 AM
silverevo05's Avatar
^ Actually that is somewhat wrong. I had the honda battery not the R version (switched + and - posts) with the Muse short route upper which is a bushur knock off (I believe) then I went with a miata battery from autozone in the standard orientation (like the stock one) and cut the tray. I was still able to fit the same Short route upper.
I prefer the miata because its smaller and much more reliable and readily avaiable than the mini batteries.
Old Oct 28, 2013 | 09:43 PM
Coqui's Avatar
Coo thanks.. I got an extra tray and picked up a fairly new Honda battery from friend...if it doesn't work then I'll re trim tray for miata battery.
Old Oct 28, 2013 | 11:04 PM
shangai's Avatar
I had the ets short pipes and they got rustall the way. And no alky was injected. 😩. On the bat I swap it to the trunk! Better than a. Small one. Agm type👍👍
Old Oct 28, 2013 | 11:14 PM
Coqui's Avatar
^^^I'm doing the wrinkle black pipes so no rust issues....man I need to get back to PR..got family thru out there
Old Oct 28, 2013 | 11:24 PM
llDemonll's Avatar
good luck
Wow...they sure as **** are...those are fantastic prices
Old Oct 30, 2013 | 11:05 PM
shangai's Avatar
My rust came from the inside. So I made a new one out of alum 👍😁
Old Oct 31, 2013 | 12:19 AM
the older ets V1 pipes had a rust issue which was resolved.
On the Miata AGM battery, I got the wet cell version. The neat part about the AGM is you can mount it anywhere in whatever orientation you want, BUT it does have problems when trying to recharge it (must be done on a slow charge) thats why I just got the wet cell miata one.
Old Oct 31, 2013 | 11:28 AM
Coqui's Avatar
Thanks I'll keep that in mind
1SlowRS
Mar 28, 2017 02:35 AM
Casey Robertson
Oct 25, 2016 10:27 AM
2rbolag
Oct 2, 2016 01:00 PM
2rbolag
Sep 28, 2016 11:26 PM
Tekniq
Dec 21, 2012 12:40 AM
